Activity Forums Audio Best inexpensive recorder
  • Best inexpensive recorder
    Posted by Stephen Lewis on June 20, 2013 at 7:05 am
    I just bought a Sound Devices 302 mixer. Yay! I have a Zoom H4n but I hate it because the XLR inputs are mic only and the TRS inputs are line level but unbalanced! (the 302 xlrs are balanced)
    The Tascam DR 40 looked nice and I was going to buy it but I thought I ought to consult the seasoned sound professionals here on the COW first. Can I get GREAT audio with the SD302/DR-40 pairing? Would you suggest a different portable audio recorder?
    What is the best way to interface the two? 302 xlr to DR40 xlr or some other combination of outputs/inputs on the two devices?
    Thanks for any help!
    PS: If I wanted to output audio from the 302 to BOTH a camera with a 3.5mm jack and an audio recorder (like the DR40), how would I do it?
    PPS: If these seem like dumb questions it’s because I literally have no idea what I’m doing. Just thought I’d be frank with all of you.
    Eric Toline replied 13 years, 2 months ago 4 Members · 21 Replies
  • 21 Replies
  • Craig Alan
    June 20, 2013 at 11:56 pm
    [Stephen Lewis] “I have a Zoom H4n”
    vs
    [Stephen Lewis] “Tascam DR 40”
    Not a lot of difference in quality. To me a waste of money to buy the other if you have either one.
    on the 302:
    Line-Level or Mic-Level (or somewhere in between)
    The XLR Output Level can be attenuated anywhere from a Line level signal to low Mic level signal.
    See Setup Menu for adjustment.
    I’m pretty sure you can use the tape out with the right interconnect to go to your camera. I haven’t done that and if no one else answers call sound devices tech support. They give great support.
    Mac Pro, macbook pro, Imacs (i7); Camcorders: Panasonic AG-HPX170/AG-HPX250P, Canon HV30/40, Sony Z7U, VX2000, PD170; FCP 6 certified; write professionally for a variety of media; teach video production in L.A.
  • Eric Toline
    June 21, 2013 at 2:24 pm
    I’ve got a DR40 that I feed from a Sound Devices 442. The DR40 line in will accept both an unbalanced or balanced input. I would suggest feeding your DR40 from the TA3 2 channel unbalanced mixout connection on the 302 to 2x 1/4″ mono tip, sleeve unbalanced plugs. Doing it that way leaves the 302 XLR’s for feeding another camera, recorder whatever.
    Self serving plug follows: If you are hesitant about building the mix out connecting cable I can do it for you. I make and offer all types of audio interconnecting cables. For more info: 954-255-7628
    Eric
    “I push the RECORD button and hope for the best”
  • Craig Alan
    June 21, 2013 at 2:48 pm
    Eric, is that like one of these?
    https://www.bhphotovideo.com/c/product/293005-REG/Sound_Devices_XL_3_XL3_Mini_Male_to.html
    If so what do you charge?
    We use 7 mixpre-d’s under out smaller cams and the students have broken a couple of these cables. What do you charge?
  • Eric Toline
    June 21, 2013 at 3:43 pm
    The cable in the B&H listing is what you want. I charge $30 each. Please call me and we can discuss exactly what you need. 954-255-7628
    Eric
  • Ty Ford
    June 21, 2013 at 3:52 pm
    Craig,
    Eric has made many cables for me.
    Enjoy,
    Regards,
    Ty Ford
    Cow Audio Forum Leader
    Want better production audio?: Ty Ford’s Audio Bootcamp Field Guide
    Ty Ford Blog: Ty Ford’s Blog
  • Craig Alan
    June 23, 2013 at 5:52 pm
    Thanks Eric. I don’t have a budget right now but will keep you on file for future needs. Is it worth sending you broken cables for repair or is it best to start from scratch? Also would you advise my learning how to do these repairs or is it best left to a pro? Our XLRs take quite a beating too.
  • Eric Toline
    June 23, 2013 at 8:11 pm
    If your cables are taking a beating because of carelessness then it’s up to you to have a talk with those people and to hold them responsible for the repair or replacement costs. There is no excuse for that kind of irresponsibility. Since you seem to be on a limited budget I would suggest you learn to repair the cables yourself.
    Eric
  • Ty Ford
    June 23, 2013 at 8:24 pm
    Craig,
    Your XLRs take a beating? Please explain how and why this happens.
    Regards,
    Ty Ford
  • Craig Alan
    June 24, 2013 at 12:00 am
    Sorry I worded it that way. I have a pretty good track record in terms of loss and damage to production gear. However, I am lending out gear to hundreds of students day in and day out during the school year.. Every so often i find an xlr cable that seems to have a loose connection. If I had an inexpensive way to repair the connection I would. But I have never done these type of repairs. I assume I’d have to learn to solder and follow a wiring diagram.
  • Ty Ford
    June 24, 2013 at 12:34 am
    Ah, students!
    Yes, got it.
    Get a small Weller soldering pencil and some solder and jump right in. It doesn’t take a lot to learn and it will save your butt. I have Eric do my big jobs, but I still handle the occasional soldering chores that pop up.
    Regards,
    Ty Ford
    https://www.radioshack.com/product/index.jsp?productId=3348443
Page 1 of 3
