Activity › Forums › Apple Final Cut Pro Legacy › best image still file format for animating and compositing photos in a doc-film???
  • best image still file format for animating and compositing photos in a doc-film???
    Posted by Nick Natteau on February 10, 2012 at 7:13 pm
    I’m making a documentary film that will use many animated composited photos as in the doc-film “Cocaine Cowboys”.
    Can anyone tell me what format the stills should be in for compositing in Final Cut Pro 7??? TIF? PSD? PNG?
    Or should I instead be using After Effects for animated composited still work. I just figured FCP7 because that’s what I’m editing my project in.
    I’m just unsure which still format to use. I just now that I’ll need transparency, alpha channels, etc.
    Also I’ll be scanning a lot of photos for this film from the National Archives. What format is best to scan in? I’ll be doing a lot of Ken Burns type animated moves on stills too.
    Thanks very much in advance for any tips, help.
    Scott Roberts replied 14 years, 7 months ago 5 Members · 4 Replies
  • Shane Ross
    February 10, 2012 at 7:36 pm
    TIF and PNG are best. If you do this in FCP, they need to be under 4000 pixels in dimension. You cannot work with 8000×6000 files. FCP will choke.
    I recommend using After Effects for this. No file size limit, works with any format, the moves are smoother, and compositing is easier.
    Shane
    Little Frog Post
  • Bret Williams
    February 10, 2012 at 8:32 pm
    Except for working with audio timing. I wonder, now that Automatic duck is free, if you could use the large photos and time them in FCP, and then export the XML to After Effects to do the moves/compositing. Just lay them out in time to the music/narration in FCP with specific overlap, then use AE to do the rest. I would think that would work.
  • Michael Gissing
    February 10, 2012 at 10:58 pm
    Motion doesn’t have the 4k limit. I am not a Motion user for this sort of animating but I think you can have synced audio
  • Scott Roberts
    February 12, 2012 at 7:46 am
    I’d use the Targa format. I made a quick video tutorial on making alpha channels in Photoshop for use in editing programs:
    https://www.youtube.com/watch?v=aXqLaDDXvGs
    LittleBlackBird.net
    My Blog
