Activity › Forums › Apple Final Cut Pro Legacy › Best HD camera to use with FCP for $5000 or less?
Chris Williams replied 16 years, 6 months ago 10 Members · 13 Replies
Jayme Rodriguez
April 2, 2010 at 6:40 pmHey Chris- can you help me transfer clips from my HPX 170 to FCP6? When I tell it to “Capture Now” I can hear the Mac running, but a black window pops up and says it’s waiting for timecode. Ugh…
-Jayme
Shane Ross
April 2, 2010 at 6:46 pmYou don’t use LOG and CAPTURE…that’s for tape. P2 is tapeless, and requires a different workflow.
TUTORIAL!
Shane
Read my blog, Little Frog in High Def -
Chris Williams
April 6, 2010 at 12:21 pmJayme,
You need to push “Play” on your camera first and then push the “Capture Now” button. It will then be able to find timecode, and you let it capture as long as you want it to. You then push “esc” when you reach the end of what you want to capture. Make sure you turn it off before you reach the end of the tape, because it will continue to capture until you push “esc.” Hope that helps.
Chris Williams
chris@amplitudemedia.net
