Activity › Forums › Apple Final Cut Pro Legacy › best H.264 compression out of FCP
  • Rafael Amador
    May 3, 2011 at 5:44 pm
    [scott Patterson] “tried a 422 test, and sent the 422 clip through Compressor (and also QT pro) and still the graphics loo”
    Are you setting “Frame Contol ON”, Best downscaling, Deinterlacing?
    rafael
    http://www.nagavideo.com
  • Everest Mokaeff
    May 3, 2011 at 6:11 pm
    Thanks Rafael and David
    One more question to get things really complicated. In my typical workflow I capture DV, edit natively, and output thru compressor to MPEG-2 for use in DVD Studio, skipping any QT exports. Would my video at the end of the day look any better if in fcp I changed compressor from DV to ProRes? I wanna make sure that we’re on the same page here: I do not export thru QT and then re-encode in Compressor. I send sequence to it. Does changing compressor type make any difference in this pipeline? Sorry if you answered this question thousand times before.
    Free-lance fcp editor in Moscow
    http://www.mokaeff.com
  • Scott Patterson
    May 3, 2011 at 7:03 pm
    turned those on in compressor, saved as a new setting, and the 10 second test clip was taking 15 minutes to render. quit that.
    As another test for the convert to ProRes workflow suggestion, I turned the pro res test clip into a flv in Media Encoder and compared to a regular DV test clip in the same settings in Encoder and the ProRes title quality was actually worse. So although I appreciate the advice, I don’t see going there.
    My resolution is that in compressor, I changed the LAN setting to a lower data rate of 672, and saved as a new setting. it looks great. I’ll use this for client review cuts show, they’ll have a bigger frame than the 480×360 setting and the image looks better, without much increase in file size, so works for me
    Still no clue why preset 480×360 straight outta fcp is abs fine, but when using same setting in Compressor or QT pro it’s ugly. Will remain a mystery it seems
  • David Roth weiss
    May 3, 2011 at 7:13 pm
    [scott Patterson] “I turned the pro res test clip into a flv in Media Encoder and compared to a regular DV test clip in the same settings in Encoder and the ProRes title quality was actually worse.”
    You must be doing something wrong then. A title that gets hit by 8-bit DV compression in 4:1:1 color space can’t be better than the same title compressed with ProRes at 10-bits in 4:2:2 color space.
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    https://www.drwfilms.com
    A forum host of Creative COW’s Business & Marketing and Apple Final Cut Pro forums. Formerly host of the Apple Final Cut Basics, Indie Film & Documentary, and Film History & Appreciations forums.
  • David Roth weiss
    May 3, 2011 at 7:14 pm
    [scott Patterson] “tried a 422 test”
    precisely what did you do in this case?
    David Roth Weiss
    Los Angeles
  • Scott Patterson
    May 3, 2011 at 7:42 pm
    i duplicated the DV sequence. I changed the compression of the sequence to prores 422. I exported a 10 second clip. I opened the QT video to check and it was a pro res file.
    I exported the same 10 seconds out of the dv sequence.
    I dropped them both in Media encoder, same settings. Compared the outputs many times it was clear that the pro-res one was not as good. Artifacting around the titles. These titles were pretty big in frame.
    I just ran another test, however, with a different section where the titles are smaller. And the pro res is much better once turned to flv.
    I think in the long run if going to final deliver as a flv, I will take this route to make sure titles are a bit better. Glad I ran another test. thanks
  • Chris Borjis
    May 3, 2011 at 10:38 pm
    sometimes you have to delete your render files…
  • Scott Patterson
    May 3, 2011 at 10:44 pm
    in regards to what?
  • Chris Borjis
    May 4, 2011 at 6:03 pm
    The issue you are having…
Page 2 of 2
