Activity Forums Apple OS X Best Graphics Card
  • Best Graphics Card
    Posted by Joseph Colombatto on June 17, 2010 at 3:38 pm
    Hello,
    I am presently working on a Mac Pro (the first version), Processor 2×2.66 GHz Dual-Core Intel Xeon,
    and Memory 2 GB 667 MHz DDR2 FB-DIMM, and am looking to upgrade my current system without
    having to buy the new 8 core. (tempting though).
    Can I add Memory (Ram) to this system, (Apple Store says it’s maxed out as is), and what is the
    Best Graphics Card I can put into this present system?
    I’m beginning to do a lot of HD work, (AVCHD), and would like the highest performance possible
    with this system. Also, an external monitor, what would you suggest.
    I still transcode much of my stuff to SD, and still run my external monitor thru a DSR-11.
    I suppose I should go to an HD external, would I be able to hook the DSR-11 into that for
    SD (30p) stuff?
    Thanks a bunch,
    Joe C.
    Pasi Koivisto replied 16 years, 2 months ago 2 Members · 1 Reply
  • Pasi Koivisto
    June 29, 2010 at 4:12 am
    You should be able to upgrade to 16Gb of ram.
    Look into the Radeon 4870. I use it in my Mac Pro but it’s the revision after your but I’ve read that it works But look into it.
    I think you should consider buying 3 SATA drives, but them into your computer and do a software raid 0. It will be very fast and really help with the performance. Just remember to NOT keep project or originals on it as it has a higher risk of crashing.
    If you get a video card that can output to a HD monitor most if not all of the HD cards from AJA and Black Magic will downconvert the signal to SD.
    /Pasi
    Editor, Colorist.
    Mac Pro, 8×3 Ghz, 8 Gb ram, ATI Radeon HD 4870, KONA 3, Sony PVM20L4, Tangent Devices Wave.
