Activity › Forums › Apple Final Cut Pro Legacy › Best Freeze Frame Images?
Posted by Redford Givens on May 17, 2009 at 2:57 pmHow can I get the best definition for a freeze frame.
Some excerpts from our DVDs need to be printed 300dpi. How do we get the sharpest images?
Never Trust A Robot
Redford Givens
Massimo Petrarca replied 12 years, 3 months ago 9 Members · 10 Replies -
Steve Eisen
May 17, 2009 at 3:20 pmDo not expect high quality images from a video frame. Unfortunately the highest native resolution from a frame is 72 dpi. You can change the resolution in photoshop but it will not make the image any better.
If you are working with interlaced video, you will need to apply a deinterlace filter to it.
If you have any motion in the video, you will get a lot of motion blur in you freeze frame.
Steve Eisen
Eisen Video Productions
Board of Directors
Chicago Final Cut Pro Users Group -
Rafael Amador
May 17, 2009 at 3:31 pmYes, as Steve say.
There are some plugins for Photoshop that can upsize the picture with amazing results.
Rafael -
Tom Wolsky
May 17, 2009 at 3:32 pmI have. Excellent product. I use it for uprezzing screen shots for print in my last few books.
All the best,
Tom
Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 4 Editing Workshop” -
John Fishback
May 17, 2009 at 3:37 pmI’ve never used this, but it looks like it might be able to scale a 72 dpi image up to 300 dpi. https://www.benvista.com/main/content/content.php?page=ourproducts§ion=photozoompro_1
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
24″ TV-Logic Monitor
Final Cut Studio 2 (up to date)Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
Redford Givens
May 17, 2009 at 4:08 pmRe: Best Freeze Frame Images?
by Tom Wolsky on May 17, 2009 at 8:32:29 amI have. Excellent product. I use it for uprezzing screen shots for print in my last few books.
All the best,
Tom
I tried the sample version of PhotoZoom Pro 2 and couldn’t see any difference. Is there some trick to using this program?
Never Trust A Robot
Redford Givens
Tom Wolsky
May 17, 2009 at 5:23 pmYou open it in PhotoZoomPro and change the image resolution to like 300dpi. The application processes the image. You do a save as.
All the best,
Tom
John Ford
December 9, 2009 at 7:57 pmHi There..
I am a new comer to Finalcut, doing well with editing but i know little about exporting to the get the best of the Clips..
Is ther anything i should know about exporting a Still Image / freeze frame…??
At the moment, I just QT convert / Still image / Jpg hi quality..
Its not usable for what i need, How can i get a better/ BIGGER file out of her..???
Chreeze
john
Caleb Crosby
May 12, 2011 at 10:36 pmSimplest way is to export as TIFF not jpeg. Much larger file.
Good luck,
Caleb Crosby
boston ma -
Massimo Petrarca
June 24, 2014 at 12:50 pmHi,
I am quite new in the “video” world, so I might say some nonsense..
I am wondering why the maximum is 72dpi for video even at highest resolution.
Is there a technological limitation?So, what does it change from 2K and 1080p for example if I keep the same FOV of my GoPro?
In principle I was expecting to get higher resolution (pixel/inch ) on the horizontal axis for example.
Almost double than 1080p.
But if the pixel/inch is fixed to 72 than what’s changing?
I mean, if I get the same number of pixel to reconstruct the image of the same dimension (same FOV)
what is changing form 2K and 1080?Once again, sorry for the maybe “studio” question , the answer might be hidden in the decoding
action on the different video, but honestly I do not know.Thank you for any explanation
Max
