Activity › Forums › Adobe Premiere Pro › Best format to output video with green screen effects
  • Best format to output video with green screen effects
    Posted by Mikkell Khan on August 4, 2011 at 8:45 pm
    Hello all,
    I have been experimenting with some formats of output in premiere pro, such as mpeg, mov, avi, flv, etc. especially in the case of outputting clean and proper transparency for green screen effects.
    I have found that some formats do not do this too well, such as mpeg, such shows a lot of artifacts in the shot than what is actually seen in Premiere at the time of edit.
    I have been utilizing the ultra key and we have been using a pretty well lite green screen and subject (no shadows, no shared lighting, etc.)
    Which formats do you guys find are best for outputting video with green screen effects?
    Thanks and Best Regards,
    Mikkell Khan
    Director
    Diamond Films Ltd. (Trinidad and Tobago)
    Jeff Brown replied 15 years, 1 month ago 3 Members · 2 Replies
  • Steve Brame
    August 4, 2011 at 9:23 pm
    Best practice would be to shoot for the least compressed type of file that you can, but it also may depend on what program you are going to use your exported files in. You’re program being SD or HD can also affect the choice, as well as whether or not you’ll be doing a re-transcode in your target program. Stay away from highly compressed codecs like MPEG and FLV(unless you are using the video in a Flash movie).
    Steve Brame
    creative illusions Productions
  • Jeff Brown
    August 5, 2011 at 3:28 pm
    The question would be outputting for what? If for further FX work, then I would output file sequences, like DPX 10-bit. If you are referring to edited project/timeline output, then whatever your destination needs, same with or without greenscreen (because your project is edited).
    -Jeff
