Activity › Forums › Apple Final Cut Pro Legacy › Best format to export videos for streaming internet use
  • Best format to export videos for streaming internet use
    Posted by Travis Roesler on May 9, 2012 at 3:35 am
    I am going to be providing a lot of videos on my website and I’m trying to maintain some quality while decreasing loading time and data usage.
    Most of my videos are about 10 minutes long and HD… just exporting them can take multiple hours using my current settings. Some of them I will host on youtube, so I just upload and let them sort it out… the paid content I need to stream from my site itself, and I expect a lot of usage. I’ve also considered uploading to youtube and then downloading the file that their conversion process creates… however, this still doesn’t solve the insane time it takes me to export the vid itself.
    Right now I’m using for video:
    h.264
    high quality
    key frame rate 24
    600×318 for dimensions
    for audio:
    ima 4:1
    Thats all I know…
    Thanks for your time guys!
    Travis Roesler replied 14 years, 4 months ago 3 Members · 3 Replies
  • Rafael Amador
    May 9, 2012 at 9:14 am
    For affordable fast conversion you should try something like this;
    https://www.elgato.com/elgato/na/mainmenu/products/Turbo264HD/product1.en.html
    [Travis Roesler] “h.264
    high quality
    key frame rate 24
    600×318 for dimensions”
    For quality, set Multipass and the keyframes AUTO.
    Restrict the date rate. For that size i would start to try something like 500Kbps.
    rafael
    http://www.nagavideo.com
  • Alex Elkins
    May 10, 2012 at 4:33 pm
    Those settings are kind of overkill for the web. Also, 800×318 is quite an annusual (although not unheard of) aspect ratio. Is your material standard 16×9 widescreen?
    Try the following format:
    h264 mid/high (move the quality slider to a little but above the half-way point.)
    Key Frames: Automatic
    Dimensions: 1280 x 720
    Audio:
    AAC
    48kHz
    128kbps stereo or 64Kbps mono (I usually only bother with stereo if there are audio pans that have a real affect on the viewing experience and for music videos where obviously audio quality is important).
    If you’re finding the encoding takes too long, switch the video settings to single pass. Quite often this is perfectly acceptable anyway.
    Make sure your video is rendered inside FCP first. This will speed up the encode as well.
    You might also want to look into setting up a Qmaster cluster for rendering with Compressor, but that’s another topic entirely.
    Alex Elkins
    Twitter: @postbluetv
    http://www.postblue.tv
    Post Blue showreel
    Latest work: Greyhounds in Motion at 500fps
    My Vimeo Pro page
  • Travis Roesler
    May 10, 2012 at 6:25 pm
    Amazing… Thank you very much. I will try this and let you know how it goes
