Activity › Forums › VEGAS Pro › Best format to convert JVC MOD file into for editing
  • Best format to convert JVC MOD file into for editing
    Posted by Thomas Steel on October 1, 2010 at 4:16 am
    Hey all.
    I have had a few problems getting my new jvc camera to import the files into sony vegas.
    The formats I have tried havnt worked and the new program I have got has hundreds of different combinations of format. encoders. bit rate. frame rate.
    Can anyone help me and reccomend a good format to convert the MOD files into that sony vegas 8 will like?
    Thanks in advance
    Thomas
    Aaron Star replied 10 years, 9 months ago 8 Members · 10 Replies
  • 10 Replies
  • Danny Hays
    October 1, 2010 at 7:13 am
    Your camera should have come with a converter program, but if not, here’s some links to some.
    https://www.modvideoconverter.net/mod-video-converter.htm
    https://www.modvideoconverter.net/mod-converter.htm
    https://www.avs4you.com/AVS-Video-Converter.aspx?type=GoogleImageAds&gclid=CL_bsM2OsaQCFQpe7Aodcn9e0A
    The last link is a free download.
    Hope this helps, Danny Hays
  • Mike Kujbida
    October 1, 2010 at 8:56 am
    I’ve never had any problems simply dropping .mod files on my Vegas timeline.
    If that doesn’t work, copy a few of them to a new folder and rename them by changing .mod to .mpg.
  • Thomas Steel
    October 9, 2010 at 9:46 am
    I have the converter. my problem is finding the best format for sony vegas 8.
    I originaly tried mpeg files but soon found out that vegas doesnt like them and it keeps crashing on me.
    Instead of going through more trial and error I thought Id ask online incase someone has done it already.
  • Thomas Steel
    October 9, 2010 at 9:47 am
    when I drop my MOD files into vegas i get no audio. and when i change the file name to .mpg the same happens. if there is a setting in vegas to import mod files with audio that would be helpful
  • Katarina Gallova
    November 28, 2010 at 1:13 pm
    Convert it into .avi (lossless format) and then you can cut your work without any problem at the best picture quality, although, mind the huge files .avi format makes
  • Mike Kujbida
    November 28, 2010 at 3:45 pm
    Thomas, what version of Vegas are you running and is it Pro or Movie Studio?
  • Zara Ashton
    January 7, 2011 at 10:56 pm
    You don’t need to convert a .mod file if you have Vegas Movie Studio HD Platinum 10. It reads them. When importing your media, under the ‘Files of type’ drop-down, make sure you scroll to the top and select ‘all files’. Then you’ll see the .mod file. Select it and add. If your video was filmed in 16:9 widescreen format you’ll need to alter its pixel aspect ratio so that it displays correctly. To do this, right-click on the file’s icon in the media window, go to Properties then Pixel aspect ratio, and select the appropriate ratio for your desired output (e.g. if you’re going to create a widescreen DVD for a PAL audience Europe/UK, select PAL DV Widescreen).
  • Daniel Kathee
    July 29, 2013 at 8:21 am
    Have you tried iDealshare VideoGo which can convert all kinds of MOD files to almost all popular video format like MP4, MPEG, AVI, WMV, MKV, VOB, MOV, DV, FLV, Apple ProRes, 3GP, OGV, and etc
    It has both Mac version and Windows version
    Step by step guide at https://www.idealshare.net/mod-converter.html
  • Ron Mooski
    December 30, 2015 at 11:31 am
    JVC video camera is a true hybrid that has been redesigned to provide satisfaction no matter what you choose to record, and offers unique advantages as an all-in-one camera. JVC video camera user can can record HD videos from their device, but problem arises when they have to transport their JVC videos to other moveable media devices or mobile, because JVC recorded videos format are not supported by most of the portable gadgets, it can’t be played on Computer.
    In order to use video recorded from JVC camera it must be converted to popular video formats such as FLV, 3G2, MKV, MPEG-4, MPEG-1, ASF, M2TS, MOV, 3GP, SWF, MPEG-2, AVI, WMV, VOB etc with the help some third party repair tool. And best software available is JVC Video Camera Converter. This tool can transform audio formats like WMA, MP2, M4V, WAV, AMR, AU, AIFF, MP3, FLAC, OGG, and so on. Moreover you can edit videos as per your requirements like cropping, merging, trimming, adding water mark, subtitle, contrast, saturation, and lot more.
  • Aaron Star
    December 31, 2015 at 5:55 am
    Vegas does not import audio for formats it does not understand. This could be AC3 or some other format. Using “Media Info” utility to determine the audio format is the 1st thing I would try.
    Then I would looking into something like FFMPEG. FFMPEG with the right command can copy the video stream, and convert the audio to uncompressed PCM, then wrap that into MXF or AVI.
    Optionally you could convert your material to DV for SD, or XDCAM.MXF or Cineform.avi for HD. The audio import issue is the same, only converting to any of those formats will automatically change the audio to PCM.
