Activity Forums Adobe Premiere Pro best format to convert AVCHD for editing?
  • best format to convert AVCHD for editing?
    Posted by David Lord on June 26, 2013 at 3:35 pm
    hi everyone. I have a 2012 imac and I want to edit some video from my Sony hdr-cx160 camera. I’m using premiere pro cs6, but before I start a project, I’ve been doing research on the AVCHD format. Apparently its difficult to edit in because of its compression. I guess I need to convert the format first, but I don’t want to lose any quality at all, otherwise that would defeat the purpose of buying the HD camera. I’ve found a lot of info on various codecs. Some say cineform is the best, some say ProRes, but only for final cut, some said I should use QuickTime player to convert to. mov. All I’m really concerned with is what will preserve all of my quality, and work with premiere pro since that’s what I’m using. if anyone can give me advice, id appreciate it!
    Chris Borjis replied 13 years, 2 months ago 3 Members · 10 Replies
  • 10 Replies
  • Shane Ross
    June 26, 2013 at 4:47 pm
    Well, first off, Adobe works with nearly all formats natively. You just need to make sure you have fast processors, gobs of RAM, and a graphics card that enables CUDA. But converting AVCHD always helps…it’s very processor intensive.
    Now onto this statement:
    [David Lord] ” I guess I need to convert the format first, but I don’t want to lose any quality at all, otherwise that would defeat the purpose of buying the HD camera.”
    Every feature film you have seen in the theater is not shown in it’s native format. Let’s say it was shot with the RED camera. It was converted to another format before editing, for sure. But then they probably went back to the original for color correction, rendered out to another codec…compression. Then made into Digital Intermediate…another compression, then delivery format…compression.
    Every TV show on TV…we convert the footage to another format, be it ProRes or DNxHD…and then compress a couple times before it sees air. EVERY professional converts the footage to another format. It does not defeat the purpose of an HD camera. Besides, it’ll get compressed again when it goes to BluRay…or DVD…or H.264 for web or computer…or output to tape…or compressed for satellite or cable delivery.
    That’s just to tell you that professionals convert camera masters to workable formats all the time…and it still looks great.
    Work native if you want…just make sure you have the resources for it. Or you can convert to ProRes, if you have a Mac and some Apple App that gives you that codec (like Compressor, or Motion)…or you can download the Avid codecs (free), Cineform codecs (free…get Cineform Studio Free) and use those.
    Shane
    Little Frog Post
  • David Lord
    June 26, 2013 at 4:58 pm
    thanks! that was very helpful. I suppose I wouldn’t mind editing natively if my computer can handle it. I maxed out the RAM, (32 gb) , it has an U-Haul processor, but I don’t think the graphics card can use CUDA. (It wasn’t highlighted in the preset settings) I believe the card is an nvidia geforce 680. in your opinion can this computer handle the AVCHD natively?
  • Shane Ross
    June 26, 2013 at 5:15 pm
    What kind of Processor? i7? i5? less?
    Without CUDA, it’ll work with it, but not smoothly. And the longer the sequence, the more unruly it becomes.
    Shane
    Little Frog Post
  • Chris Borjis
    I edit AVCHD from a sony nxcam almost daily.
    Your system should be fine.
    see if you can enable the one you have manually. (do a google search for that)
    Having a CUDA or OpenCL capable card will make your workflow smoother for sure.
    But you should be able to edit that footage as is.
  • David Lord
    June 26, 2013 at 5:22 pm
    my processor is an i7! haha my auto correct changed it to “u haul ” for some reason. but thanks for the tips, ill try to find out if I can use CUDA with my card too
  • David Lord
    June 27, 2013 at 2:06 am
    Ok, I was able to enable CUDA for my graphics card, and I imported some .mts files just to experiment. Looks like its going to work smooth! But just for comparison purposes, I’d like to play around with cineform a little too, just to see if I like it better. I downloaded “cineform studio”, but I dont know how to use the codecs from it. When I run the program, I choose “import”, but for some reason my AVCHD files are grayed out, (both on my hard drive and with the camera plugged in) How do I convert the files?
  • Shane Ross
    June 27, 2013 at 9:16 am
    You convert with PRELUDE, or MEDIA ENCODER. But this is best for PRELUDE.
    Shane
    Little Frog Post
  • David Lord
    June 27, 2013 at 2:27 pm
    sorry if this is an obvious question, I’m not at my computer right now, but I just did a search on my phone, and a lot of people posted that cineform isn’t an export option in prelude. is there some other step I have to take to accomplish this?
  • David Lord
    June 28, 2013 at 1:05 pm
    anything guys? seemed like some of you knew how to do this up until this point.
  • Chris Borjis
    June 30, 2013 at 7:28 pm
    Not sure if you can now…cineform is owned by gopro now…
    maybe install gopro utilities to get that codec?
