Activity Forums Adobe Encore DVD Best format from Premier
  • Best format from Premier
    Posted by Rich Rubasch on October 28, 2010 at 3:21 pm
    Have a Premier project with Blackmagic AVI codec at 720 59.94 and need to send 15 sequences to Encore for a BluRay output. Is there a setting in Encore that automatically detects the 720 clips from Premier and formats and encodes the disc to 720? Or should I encode the sequences first to self contained clips in a folder and bring those into Encore?
    Exporting the sequences directly to Encore is taking forever. I think sending the sequences thru media encoder and creating individual clips would be faster, but is 720 59.94 a proper format for BluRay and is there any preference in Encore that needs to be set to specify a 720 project?
    CS4, PC.
    Rich Rubasch
    Tilt Media Inc.
    Video Production and Post
    Owner/President/Editor/Designer/Animator
    https://www.tiltmedia.com
    Rich Rubasch replied 15 years, 11 months ago 2 Members · 2 Replies
  • Daniel Ludwig
    October 29, 2010 at 6:51 am
    Hi Rich,
    the best way would be to export your clips from premiere as a self-contained file.
    afterwards import them into encore if you need specific chapter-marker and let encore encode the clips with the chaptermarker on the timelines.
    if you wont need specific chaptermarker on a specific TC you an also do a bach-prozess within adobe media encoder to create your assets.
    if you starting encore make sure your project-settings are 720p59.94 if not, all your material will be scaled to the selected format (1080 for example).
    als be awared that you can´t use different input-materials with encore as the BD-spec normally allow.
    all stuff will be scaled/transcoded to the selected setting.
    and finally – yes, 720p59.94 is part of the BD-specs.
    cheers
    danny
  • Rich Rubasch
    October 30, 2010 at 2:05 am
    That was an awesome response….thanks!
    Rich Rubasch
    Tilt Media Inc.
