Activity Forums Adobe Illustrator best format for saving illustrator file to be printed on desktop printer
  • best format for saving illustrator file to be printed on desktop printer
    Posted by Celeste Cochran on August 21, 2009 at 4:20 pm
    I am doing a logo, business card, and stationary design for a customer who wishes to print them from her desktop printer. I was wondering what the best file format would be so that the formatting would be retained. Would a PDF be the best suited for this purpose? If so, how would I set the preferences up for saving? thanks!
    Celeste Cochran replied 16 years, 11 months ago 2 Members · 6 Replies
  • Nel Westmaas
    September 17, 2009 at 8:07 am
    Hi there, did you ever get a response to this question?
  • Celeste Cochran
    September 17, 2009 at 3:13 pm
    No, I never did.
  • Nel Westmaas
    September 17, 2009 at 3:57 pm
    Hi celeste, well I was only asking becaus ethat is exactly what I have been working out over the last week. So i have learned quite a bit and have some much better results now.
    The best i can say at this moment is that the file you create should be in adobe rgb1998 workspace. When you save the illustrator document make sure that “save compatible pdf” is ticked ON. Open the pdf by going to your normal illustrator file and hold command key as you click the file, you will see the option to open WITH pdf – at this point I am assuming you have an apple mac? On windows it is probably right click the mouse and open as. The illustrator file will open as a pdf. save this as some suitable name to send to her.
    we can take it from here if you have any problems. But Sending her a pdf is the best way.
    Kind regards
    Chris
  • Celeste Cochran
    September 17, 2009 at 8:19 pm
    thanks so much. I have a pc but, as you said, I’m sure there is an alternate method. what does the number next to the rgb refer to?
    Celeste
  • Nel Westmaas
    September 17, 2009 at 10:00 pm
    Hi if you mean 1998 I have no idea, but if you meant something else please clarify.
    Kindest regards
    Chris
  • Celeste Cochran
    September 19, 2009 at 1:29 am
    I did mean the 1998. Maybe it’s a date but it probably doesn’t matter. Thanks for your help. Celeste
