Activity Forums Adobe Premiere Pro Best Fix for Low Lighting
  • Best Fix for Low Lighting
    Posted by Eric Naylor on August 21, 2008 at 8:27 pm
    What would you guys recommend as the best way to fix a darkened image? i.e. – adjust brightness/contrast or gamma levels, etc. I’m sure this changes depending on the image, but just seeing if there’s a general rule of thumb. Would it be best to leave the images untouched in premiere and export them to After Effects and adjust the lighting levels there? I’ve also heard that Red Giant’s Magic Bullet Looks could fix this, but would like to get some second opinions before buying it. Thanks for any help.
    A side note: I made quick adjustments using the brightness/contrasts levels and got it to a decent image. A little grainy, but figured if I made more adjustments or played with different settings I could get a more desirable image. Is this a false assumption?
    Equipment used: canon hv20 w red rock micro 35 mm attachment. Panasonic hd tapes.
    Tim Kolb replied 18 years ago 2 Members · 3 Replies
  • Tim Kolb
    August 21, 2008 at 10:06 pm
    Underexposure is best handled first with levels…maximize the luma range of the image and adjust the gamma (middle slider in the histogram) with the same tool.
    TimK,
    Director, Consultant
    Kolb Productions,
    CPO, Digieffects
  • Eric Naylor
    August 21, 2008 at 10:30 pm
    and it makes no difference if this is done in premiere or after affects?
  • Tim Kolb
    August 21, 2008 at 11:06 pm
    Not really…if you know you’ll need to work in AE, making the adjustment there will save you a render step…PPro has a waveform monitor however…which can be helpful.
    TimK,
    Kolb Productions,
    CPO, Digieffects
