Activity › Forums › DVD Authoring › Best File to encode 5.1 ac3 from in Compressor?
  • Best File to encode 5.1 ac3 from in Compressor?
    Posted by Andrew Williamson on November 17, 2008 at 4:10 pm
    Hey all,
    I’ve captured a 5.1 mix as individual channels off of a DAT sync locked to the DigiBeta Capture @ 25fps. This audio will need to be given to the DVD authorer as an .ac3 asset, so they can drop into their scenarist project.
    I was planning on going about this by making a multi channel aif in Nuendo (the DAW I use) and dropping that file into compressor with an ac3 setting. I don’t have compressor available to me right now to run any test, so is this the right way of going about things? Also is there a specific order compressor/scenarist like the L R C RL RR channels?
    Many Thanks,
    Andy
    Andrew Williamson replied 17 years, 10 months ago 2 Members · 4 Replies
  • Eric Pautsch
    November 17, 2008 at 5:14 pm
    You’ll need 6 separate AIFFs that will be used to drop into Compressor to make the AC3.
  • Andrew Williamson
    November 17, 2008 at 5:17 pm
    Is there a specific order for these to be dropped in – or does compressor let you assign which is which?
  • Eric Pautsch
    November 17, 2008 at 5:26 pm
    Once you tell compressor you want to make a 5.1 a box will appear where you drag and drop each audio file onto L/R/C/LS/RS/SUB.
  • Andrew Williamson
    November 17, 2008 at 5:27 pm
    Ace Bro. Many thanks!
