Activity Forums Adobe After Effects best file format to save ae
  • best file format to save ae
    Posted by Jeff Katerberg on June 7, 2005 at 3:44 pm
    i use premiere 6.5 and ae 5.5
    just wondering when i want to save a clip made in ae what is the best res and format to save it as in order to have it crisp and clean for premiere?
    i usually create a file at 720 x 480 and save it as an avi file at best and full res.
    is this good enough?
    thanks for any advice.
    jef
    Michael Duff replied 21 years, 3 months ago 2 Members · 1 Reply
  • Michael Duff
    June 8, 2005 at 7:34 am
    maybe have a look through the archive. There is heaps of stuff on outputting and compression.
    Yeah, you want it on best and full. Also make sure your interlacing matches up with your source and premiere settings. I think lower is the standard for DV, I’m using upper becuase that’s what my NLE prefers (not Premiere). Double check frame rate etc etc, then save it as a default.
    I think what you need to do is check what compression you are using.
    I use quicktime “animation codec”. It is lossless, and has smaller file size than uncompressed. I think you will find most people will agree. If however you are transporting the footage and need the files to be smaller maybe you can compress using something like DV.
