Activity Forums Apple Final Cut Pro Legacy Best external drive for Macbookpro and FCP
  • Best external drive for Macbookpro and FCP
    Posted by Jim Bell on March 14, 2010 at 11:17 pm
    sATA? SCSI?
    What brand/model is the big favorite? Need min 500Gb to 1TB.
    Would like something that connects over 800 firewire, new Macbook…
    …and is really easy to setup… Should be plug and play but KNOWING its not gonna b a prob would be nice… :)))
    Nick Price replied 16 years, 5 months ago 9 Members · 9 Replies
  • 9 Replies
  • Shane Ross
    March 14, 2010 at 11:32 pm
    SCSI is pretty much gone. All hard drives are SATA. CalDigit VR is good. MaxxDigital Edit Vault too. G-Drive from G Technology.
    Shane
  • Bobby Long
    March 15, 2010 at 12:13 am
    do not get LaCie… i got a cheap 1tb and it stopped being detected by my computer within a week and no longer works
  • John Foley
    March 15, 2010 at 1:10 am
    I use a 2.5″ SATA drive based enclosure that I put together myself. It can be self powered using a USB-2 port on your MacBook Pro or E-SATA with an Express-34 card adapter. e-SATA is much faster than USB.
    There are many solution for this enclosure. I used one from ULTRA products that cost me about $25.00
  • Craig Alan
    March 15, 2010 at 3:26 am
    what format of video will you be editing? does your macbook pro have an Express-34 card slot?
    OSX 10.5.7; MAC Book PRO (EARLY 2008); Camcorders: Sony Z7U, Canon HV30, Sony vx2000/PD170, Canon xl2; Pana, Sony, and Canon consumer cams; FCP certified; write professionally for a variety of media; teach video production in L.A.
  • Jim Bell
    March 15, 2010 at 7:16 am
    I will be editing SD video mostly 24fps from dvx 100b’s… My Macbook does have the express card interface.
    Thanks to all!
  • Matthew Bradshaw
    March 15, 2010 at 8:36 am
    You can buy 1TB raid drive (with 2 500Gb drives in). If you run it as raid 1 you get speed advantages although not absolute security. I got mine of ebay for less than £200. Very easy to set up. You can daisy chain other Firewire 800 drives through it if you wish.
    Matt.
  • Ben Holmes
    March 15, 2010 at 3:59 pm
    G-Tech G-Raid (great value at 2Tb) – will also work with eSATA if you get an expresscard interface, but you won’t need it.
    Also Caldigital VR are well rated (as well as ones mentioned by Shane).
    Don’t buy Lacie or WD – they are not well built enough for laptop mobile use.
    Personally – it’s hard to beat the price on G-Raids for pro use. If you’ve got the cash, get the g-raid mini which is bus-powered. With all G-Raids, get the 7200rpm ones. The G-drives are single drive – fine, but not as quick.
    Edit Out Ltd
    FCP Editor/Trainer/System Consultant
    EVS/VT Supervisor for live broadcast
    RED camera transfer/post
    Independent Director/Producer
    https://www.blackmagic-design.com/casestudies/detail.asp?case=therydercup
  • Patrice Freymond
    March 15, 2010 at 7:23 pm
    After intensive use for a whole 18 months without a glitch I would recommend the Sonnet Fusion F2. I have the 640 Go but there is a 1To version now.
    Hope this helps,
    Patrice
  • Nick Price
    March 16, 2010 at 11:15 pm
    hi there,
    i have a Gtech-graid that i bought 6 years ago, use it everyday for online. Still works great. I also have 10 iomega Ultramax drives of various sorts. 2 have died over time, but iomega have replaced them without charge….very good customer service…
    cheer
    snick
