Activity Forums Apple Final Cut Pro Legacy best exporting format : from final cut pro to dvd pro
  • best exporting format : from final cut pro to dvd pro
    Posted by Brendan Tyler on April 19, 2009 at 9:23 pm
    hi
    i’ve finished my film and need to export it into dvd pro to make my dvd
    which is the best format to export it via, to get the very best picture quality ?
    – there are a multitude of choices
    – i’ve spent ages exporting using some, only to then find that they are NOT accepted by dvd pro ?!
    – using standard quick time leaves it looking a bit grainy and not as sharp as i’d hoped
    i’d appreciate any comments & suggestions
    thank you for your time
    Brendan Tyler replied 17 years, 4 months ago 2 Members · 3 Replies
  • Michael Sacci
    April 19, 2009 at 10:21 pm
    you want to export a self contained movie with current settings. then take this into Compressor and make your m2v file and ac3 (for audio), take these files into DVDSP.
    If you have a lot of graphing or filters on your seq. you can Export > Using COmpressor, seq does not have to be rendered before you do this. In compressor you make the m2v and ac3, this will always give you the best results, but this is always a slow way to encode and it locks up FCP and Compressor for the entire process.
    If you search the DVDSP forum I have many post on getting the highest quality but this is the basic stuff.
  • Brendan Tyler
    April 20, 2009 at 3:44 pm
    Hello again
    would you mind giving me a step -by – step idiots guide? As i’ve got it into compressor (I think but as i’ve never used it before i’m stuck)
    Once in compressor how do i “make the m2v and ac3” ?
    And then what do i do next?
    I appreciate you’re time in helping me see the light . . .
  • Brendan Tyler
    April 20, 2009 at 3:49 pm
    Wow thanks for that. There is loads for me to be getting on with and to be honest I don’t understand most of what you’ve suggested but I will follow you’re instructions to the letter.
    Many thanks for your time.
    Brendan
