Activity › Forums › Adobe After Effects › Best Exported codex for FCP to AE
Posted by Tylor Larson on December 8, 2010 at 10:24 pmWhat best QT codec to export out of FCP for After effects user on a PC?
Kevin Camp replied 15 years, 10 months ago 2 Members · 1 Reply -
1 Reply
Kevin Camp
December 8, 2010 at 10:41 pmlossless animation or uncompressed 10bit are very good options but they require a lot of drive space if you’re using hd.
quicktime png is lossless and uses less drive space, but does require a bit more processing power when using it in ae. not much of a problem if you’re working with one or two clips in a comp, but if you are compositing several, it will effect performance.
if you are working in prores, then later versions of windows quicktime can read prores, so that could be an option.
quicktime photo-jpeg is also very good, and windows quicktime can read/write that codec.
avid offers several of their quicktime codecs for free, so those are options. their dnxhd is about the same as prores, and would be a good option for hd.
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW
