Activity › Forums › Adobe Premiere Pro › Best export specs for display on big screens?
  • Best export specs for display on big screens?
    Posted by Neil Orman on February 7, 2019 at 4:00 pm
    I had a question about the best (1080p) export specs for display on (auditorium) big screens at events. Most of my work is for online, and heavily compressed for that reason, and I’ve always used the Vimeo export specs. Could anyone please advise on the optimal export specs for display on auditorium screens, within PPro? My videos for this event are in 1080p sequences, so I guess their size is limited by that. Within PPro, other options I see are ‘Match source – High bitrate’ and ‘High quality -1080p HD,’ for example. I tried exporting with the ‘High Quality’ settings, and didn’t see much different from the Vimeo specs.
    Thanks for any guidance here.
    Joseph Freeman iii replied 7 years, 7 months ago 4 Members · 6 Replies
  • Tero Ahlfors
    February 7, 2019 at 5:01 pm
    There’s no one size fits all spec. You’ll need to ask the event organizer.
  • Todd Perchert
    February 7, 2019 at 6:10 pm
    The event location may have specs that work well for their system. I would do as Tero suggested and contact the event tech person to find out what would be the best specs for delivery. Some might be able to use ProRes, which would be better, less lossy, than h264. But, the “High Quality” setting doesn’t really help you much unless you are scaling to a different image size, so I wouldn’t worry about that being checked. Higher bit rate and 2 pass can help with h264.
    TC
  • Neil Orman
    February 8, 2019 at 2:06 pm
    Thank you Tero and Todd! I’m asking the event order as you advised, and will heed everything mentioned. Just one question on Todd’s point on ProRes. I don’t actually see that as an option in ‘format’ when I choose ‘export settings.’ Within PPro, how does one choose ProRes? I’m checking with the event organizer first as suggested, but just wanted to check on that, as ProRes is often cited as the best format when I’ve asked.
  • Tero Ahlfors
    February 8, 2019 at 2:29 pm
    Prores is available under Quicktime in the latest version of Premiere.
  • Neil Orman
    February 8, 2019 at 2:43 pm
    I see it now, thanks very much Tero!
  • Joseph Freeman iii
    February 19, 2019 at 11:30 pm
    Hi Neil,
    I have recently provided two projects for theatre presentation in h.265.
    The quality is outstanding, as compared to h.264.
    Good luck.
    Joseph
