Activity Forums Apple Final Cut Pro Legacy Best export solution
  • Best export solution
    Posted by Jimmy Van houdt on May 10, 2007 at 11:50 am
    I’ve been using fcp for 2 years now and have been wondering about three things that I haven’t found a real answer to.
    First: what is the best export option when it comes to exporting your cut video to import it in after effects (so it can lateron be put on dvd)? Should I go uncompressed or work with the default quicktime export that looks to me not soo crisp and full of blocks. Or should I export sorenson3 compressed, or H264? The last one takes still ages to export (on my macpro 2.66). Next what should I export to in AE, certainly when the after effects composition contains both video and some 3D space work (like an intro)?
    So what is the best workflow when it comes to exporting video from fcp for use in AE and export AE for use in compressor.
    Does it for example make any difference to export your 3D intro into h264 to lateron import it again into a combined video and 3D intro compo to export that as for ex. h264 or should I first export the intro as uncompressed, import it in the combined compo and export that as for ex. h264?
    Second: Is there an easy way to add subtitles to a video externaly so that you just need to import them in fcp and don’t need to do this by hand. Well, you’d still have to write them of course, but like that someone else could do this for you without touching the video. I don’t want srt files or something like that. Just a resulting file I can import in FCP. Is this possible?
    Thirth: Each track in fcp has some sort of selection mark in front of it, that you can move around from track 1 to 2 to 3 and so on. Now I don’t see what it does exactly. You probably know what I mean, I hope. So it’s to the left of each track, both sound and video. I thought it was to define for example which target track to paste to in case of a copy, but that doens’t seem to be the fact. Anybody?
    Thanks for your time. Really appreciate it 😉
    Ciaociao
    Walter Biscardi replied 19 years, 3 months ago 3 Members · 5 Replies
  • Walter Biscardi
    May 10, 2007 at 12:15 pm
    [Jimmy Van Houdt] “First: what is the best export option when it comes to exporting your cut video to import it in after effects (so it can lateron be put on dvd)? Should I go uncompressed or work with the default quicktime export that looks to me not soo crisp and full of blocks.”
    You export it in the same format that you cut with in Final Cut Pro. It’s not going to get any more crisp or add any quality to your video by changing the export format.
    [Jimmy Van Houdt] “Or should I export sorenson3 compressed, or H264? The last one takes still ages to export (on my macpro 2.66).”
    Compressing the video add more noise and artifacts. Leave it in the original format.
    [Jimmy Van Houdt] “Second: Is there an easy way to add subtitles to a video externaly so that you just need to import them in fcp and don’t need to do this by hand.”
    Not that I know of, unless there’s a third party plug-in out there.
    [Jimmy Van Houdt] “I thought it was to define for example which target track to paste to in case of a copy, but that doens’t seem to be the fact. Anybody?”
    Yes, that does select which track to Paste to. You Option Select the track you want to paste to.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Broadcast and independent productions.
    All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
  • Jimmy Van houdt
    May 10, 2007 at 12:34 pm
    Thanks for the quick reply.
    Regarding question 3:
    I’ll check the paste option once more. Must get it to work then.
    Regarding question 1:
    What I noticed was that when I exported standard qt from fcp that there seemed to be more artifacts than in the original footage that came from the camera. Still when compared, 13GB for 1 hour tape versus the 1GB for 5 minutes fcp default qt export, the quality should at least be equal to the imported camera footage, no? So why does it look less crisp? I don’t want to start with less quality when going into AE. And what is the diffence between the 8bit and 10 bit uncompressed exports?
    So if I imported like say sorenson3 compressed footage in AE, is it decompressed before being processed, or will my actions on these video files happen on the compressed footage right away?
    My concern: do I loose quality when for example exporting compressed, doing some manipulation in AE and re-importing in FCP in order to then export uncompressed from there?
    Thanks again!
  • Simon Blackledge
    May 10, 2007 at 12:49 pm
    If you don’t want to loose quality and your doing more work elsewhere use uncompressed..
    then compress for delivery if you must.
    You want to exort “as is”
    s
  • Jimmy Van houdt
    May 10, 2007 at 1:03 pm
    Tx,
    So should I go for 8bit or 10bit?
    Jimmy
  • Walter Biscardi
    May 10, 2007 at 1:09 pm
    [Jimmy Van Houdt] “What I noticed was that when I exported standard qt from fcp that there seemed to be more artifacts than in the original footage that came from the camera.”
    Are you looking at this on an external NTSC or PAL monitor or on your computer screen? You should be looking on a true television monitor.
    [Jimmy Van Houdt] “My concern: do I loose quality when for example exporting compressed, doing some manipulation in AE and re-importing in FCP in order to then export uncompressed from there?”
    Any and all re-compression of footage adds noise. Staying in the native format throughout will yield the cleanest results where possible.
