Activity › Forums › Compression Techniques › best export settings MPEG streamclip – DVD to AVI via FCP
  • best export settings MPEG streamclip – DVD to AVI via FCP
    Posted by Emma Sullivan on July 21, 2010 at 6:50 am
    Hi there,
    I have a number of DVDs to edit in FCP and then eventually play on media players (Patriot Box Office) for a museum exhibition. I thought to use MPEG streamclip to export the DVD as DV to then import into FCP and eventually export as a .mov. However the resulting file cannot be played in the media players.
    If i was to then bring that .mov file back into MPEG streamclip and export as an .avi would there be a noticeable loss in quality?
    What would be the best settings in MPEG streamclip to ensure best quality .avi
    Thanks in advance!
    Emma Sullivan replied 16 years, 2 months ago 2 Members · 4 Replies
  • Daniel Low
    July 21, 2010 at 8:57 am
    [emma sullivan] “and eventually export as a .mov. However the resulting file cannot be played in the media players.”
    What kind of .mov? Mov is just a wrapper – what codec did you use?
    https://www.patriotmem.com/products/manuals/boxoffice/BoxOfficeManual.pdf
    Sent from my iPad Nano.
  • Emma Sullivan
    July 21, 2010 at 11:40 pm
    I think its DV-PAL.
    Would it be better to use something like H264? or MPEG-4 Video? – I can see now on the Patriot Manual that these are supported
    Thanks for your help
  • Daniel Low
    July 21, 2010 at 11:59 pm
    Yes, certainly worth a try.
  • Emma Sullivan
    July 22, 2010 at 1:11 am
    Thanks Daniel, That did the trick!
