Activity › Forums › Apple Final Cut Pro Legacy › Best export settings for DVD/TV?
  • Best export settings for DVD/TV?
    Posted by Jae Yim on August 15, 2012 at 1:03 pm
    Hi there! So when it comes to exporting my files on Final Cut, I’m a complete novice. I’ve really always just gone with the default settings because they would only end up going to YouTube.
    However this time, I am cutting a wedding video together and I will need to burn the movie onto a DVD disc. I assume they will watch it on both their computers and their television set and I was wondering how I could retain a lot of the HD value onto it so that when they watch it on their TV, it will look great.
    Whereas YouTube gives you the option to make your video go from 360p to 720p or 1080p, televisions can’t do that, so I was wondering if there was a kind of export setting on FCP that would allow it to play in 720p automatically.
    I don’t know if this information will help but I have Final Cut Pro 7.0.3 and the footage was shot on a DSLR at 60fps.
    Beth Schneider replied 13 years, 3 months ago 3 Members · 2 Replies
  • Shane Ross
    August 15, 2012 at 3:02 pm
    DVDs are standard def only…720×480. So that’s all they can play back. Author a DVD and SD is all you get. If you want HD, then you need to author a BluRay disk…and hope the clients have a BluRay player. But then you need a BluRay burner, and BluRay authoring software like Adobe Encore or Toast 10.
    Ask what the clients want…work from there.
    Compressor, that comes with FCP, has presets for DVD compression.
    #42 – Quick and dirty way to author a DVD
    Shane’s Stock Answer #42 – David Roth Weiss’ Secret Quick and Dirty Way to Author a DVD:
    The absolute simplest way to make a DVD using FCP and DVDSP is as follows:
    1. Export a QT movie, either a reference file or self contained using current settings.
    2. Open DVDSP, select the “graphical” tab and you will see two little monitors, one blue, one green.
    3. Select the left blue one and hit delete.
    4. Now, select the green one, right click on it amd select the top option “first play”.
    5. Now drag your QT from the broswer and drop it on top of the green monitor.
    6. Now, for a DVD from an HD source, look to the right side and select the “general tab” in the track editor, and see the Display Mode, and select “16:9 pan-scan.”
    7. Hit the little black and yellow burn icon at the top of the page and put a a DVD in when prompted. DVDSP will encode and burn your new DVD.
    THATS ALL!!!
    NOW…if you want a GOOD LOOKING DVD, instead of taking your REF movie into DVD SP, instead take it into Compressor and choose the BEST QUALITY ENCODE (2 pass VBR) that matches your show timing. Then take THAT result into DVD SP and follow the rest of the steps. Except you can choose “16:9 LETTERBOX” instead of PAN & SCAN if you want to see the entire image.
    Shane
    Little Frog Post
  • Beth Schneider
    July 1, 2013 at 4:57 pm
    Hi Shane,
    Read your post, thank you. For some reason when I am exporting the quicktime file from fcp for the dvd authoring process I am getting a handfull of glitches at edit points that are not there in final cut on quick view or when I export using quicktime conversion. Do you have any suggestions?
    I too am a beginner with much of the technical stuff and want to add simple chapters to my instructional dvd project. Would I go through compressor first and then create the chapters in idvd or studio pro?
    Thanks for your help.
    Peace,
    Beth
