Activity Forums Apple Final Cut Pro Legacy Best Export Settings for best DVD quality
  • Best Export Settings for best DVD quality
    Posted by Uriel Reyes on July 31, 2010 at 8:37 pm
    Hey peeps;
    I’ve read many posts on this site and on others, or maybe I’m just not looking hard enough, but timesawasting; So here’s what I’ve done thus far.
    My project file is 58 minutes long. I first exported as an H.26 format with ACC audio, I know this is for web only format, but i didn’t know better. It compressed to 5.2 gb then i burned it through idvd.
    Outcome? Quality sucked for tv use.
    After doing some research, i Next exported my timeline straight through compressor, set it up as Best Quality 90 DVD, set my target location, and hit submit. Now I have 2 separate files on my desktop.
    What the hell do i do with these? I tried opening them through idvd, but no dice.
    I don’t have dvd studio pro. even if i do, would have to sit through a damn tutorial, which i dont have time for.
    So. What other option do I have with these two files after compressor?
    Please Help!
    thanx
    Mark Jenner replied 16 years, 1 month ago 4 Members · 5 Replies
  • Bill Willins
    July 31, 2010 at 9:31 pm
    Compresor has create your video ( MPEG2 ) and audio files … those are the two files. I;m not sure how IDVD works , as we use DVD studio pro here. But I can give you this one hint that may help. When you drop that Video & audio file onto the DVD creation timeline, they must have the exact same names… not the file format’s , these will be different , but the file names must match exactly. Hope this helps.
  • Chris Tompkins
    July 31, 2010 at 10:18 pm
    You didn’t mention what format your original footage is??
    Capture and edit in the highest quality u can. Do not use H.264.
    Export from your timeline using “Current Settings”
    Make a ref file. Saves HD space.
    Drop this ref file into compressor.
    Create the A/V DVD files.
    Import them into iDVD.
    Make DVD.
    Chris Tompkins
    Video Atlanta
  • Uriel Reyes
    July 31, 2010 at 10:32 pm
    dude;
    thanx a bunch!
  • Uriel Reyes
    July 31, 2010 at 10:34 pm
    dv/dvc pro 30fps. used dvx 100
  • Mark Jenner
    July 31, 2010 at 11:35 pm
    hi there
    export the time line as a photojpeg codec highest quality setting
    25 frames per sec
    then hit enter go in to next button and set de interlace and also video size 1024 x 576 for 16.9
    audio 48k
    and hit encode
    then put that fie in to idvd or waht ever you now have a very high quality quicktime mov that you can make a great dvd from
    best regards
    mark j
