Activity Forums Avid Media Composer Best export settings for Avid Media Composer 6?
  • Best export settings for Avid Media Composer 6?
    Posted by Nicole Favale on September 9, 2012 at 11:06 pm
    What would be the best export setting for me to get the highest quality .mov? I can’t use “same as source” since it will be too big for a DVD. I used to use Apple Pro Res, but that does not seem to be an option here. The image below shows my options. Thanks!
    Paul Poirier replied 12 years, 2 months ago 3 Members · 4 Replies
  • Job Ter burg
    September 9, 2012 at 11:15 pm
    Don’t use the QT encoder. If you set Custom QT export options in Media Composer, you will be using it. Export Same-As-Source or QT Ref and use Sorensen Squeeze to create something that fits your delivery format.
  • Nicole Favale
    September 10, 2012 at 4:29 pm
    Ok thanks! I checked out Sorenson Squeeze and can’t afford it. Should I get Compressor 4? I could export same as source and then use that, right?
  • Job Ter burg
    September 10, 2012 at 4:59 pm
    If you own MC6 or SY6, you own a Sorensen Squeeze license.
  • Paul Poirier
    June 27, 2014 at 12:04 am
    Newbie here….
    but it’s my understanding that you can’t send a QT reference to Sorenson if you’re using AMA. What is the best option for exporting to youtube if you’re using AMA?
    thanks
