Activity Forums Adobe Premiere Pro BEST EXPORT SETTINGS FOR 7d IN PREMIERE PRO?
  • BEST EXPORT SETTINGS FOR 7d IN PREMIERE PRO?
    Posted by Dom Fisher on April 9, 2013 at 1:23 pm
    Hi I set up a dslr 1080 25 frames per sec sequence and dragged in my h.264 movs to edit, I exported at h.264 hdtv 1080 high quality and it came out slightly pixelated. I also tried exporting with sequence settings and same result- slightly pixelated and not as good as the original movs. It only rendered out as an mp4 or mpeg using these export settings, is that right? what are the best settings to export to so i don’t loose any quality? please help
    Tero Ahlfors replied 13 years, 4 months ago 3 Members · 3 Replies
  • Jordan Westhoff
    April 9, 2013 at 6:27 pm
    Are you editing on a Mac, or PC?
    If you are editing on a Mac, I would transcode your assets to ProRes pre-import, edit and then export a ProRes file. Then compress to an MPEG or h.264 file for authoring or web upload. This should yield the best quality and better render times in addition.
    Hope this helps!
    -Jordan Westhoff
    Rochester Institute of Technology
    BS Digital Cinema/Motion Picture Science 2015
  • Dom Fisher
    April 9, 2013 at 6:38 pm
    hi i’m editing on a Mac but pro works with native footage so i was under the impresssion there was no need to convert it?
    you can see details of my export in this link so check it out let me know what you think…
    https://forums.creativecow.net/thread/3/938532#938549
  • Tero Ahlfors
    April 10, 2013 at 4:25 am
    Please don’t double post. One thread should suffice.
