Activity › Forums › Adobe Premiere Pro › Best export setting / compression for DVD output.
  • Best export setting / compression for DVD output.
    Posted by Dan Leow on March 4, 2012 at 9:13 am
    Hi
    Hopefully someone might have an answer for this.
    I am looking to export my work from Premiere Pro cs5 to DVD. Just wondering whether someone could point me in the right direction for
    1) Best compression – loseless quality for DVD?
    2) Using Adobe or other platforms?
    Thanks.
    Jeff Greenberg replied 14 years, 6 months ago 2 Members · 1 Reply
  • Jeff Greenberg
    March 4, 2012 at 3:35 pm
    Dan,
    The answer is the same for both questions.
    The length of your video dictates the data rate. The higher the data rate=less compression.
    The highest VBR MPEG-2 encode that permits you to have Audio on a fixed size disc under 9mbs.
    So, 560/# min = data rate (using AC3/dolby audio).
    Best,
    Jeff G
    Certified Master Trainer | Adobe, Apple, Avid
    You should follow me (filmgeek) on twitter. I promise to be nice.
    My book (with Richard Harrington and Robbie Carman)- An Editor’s Guide to Adobe Premiere Pro
    Lynda.com – Compressor Essentials 3.5 and 4
    Contact me through my Website
