Activity Forums Apple Final Cut Pro Legacy Best Export option for web streaming/youtube?
  • Best Export option for web streaming/youtube?
    Posted by Uriel Reyes on August 15, 2009 at 1:35 am
    Hey guys and gals;
    Helping out a friend who used his Canon XH A1 with settings set to HD-1080i/480i-24F. Then logged to Final Cut Pro 5.1.2. with an easy setup of 1080p24. What is the best Export setting to for Internet Streaming/ Youtube?
    David Roth weiss replied 16 years, 8 months ago 4 Members · 3 Replies
  • Tom Brooks
    August 15, 2009 at 11:32 am
    For youtube start with Compressor’s H.264 LAN setting in the Web/QT 7 Compatible folder. Make a copy and change Data Rate Restrict to 3000 – 8000 Kbps. That setting should get you good HD quality in YT. YouTube
    Final Cut Pro 6.0.5, Mac OS-X 10.5.6, Quicktime 7.6, Adobe Prod Prem CS4, G5 Quad 2.5, Kona-LHe V6, 8.5GB RAM, Nvidia GeForce 7800-GT 256MB, G-RAID 2x1TB FW800, 6TB RAID-5 (Enhance E8-ML, Highpoint 2322), Panasonic HVX-200P P2. Also MBP 17″ Core 2 Duo 2.5, 4GB, GeForce 8600M GT 512MB.
  • Noah Graff
    January 6, 2010 at 11:14 pm
    I shot my video on a sony PD170. The dimensions are 4 x 3. The video is interlaced (which I know isn’t good for youtube).
    I know youtube makes things look terrible and that’s a fact, but I want the best compression settings possible.
    Lots of the forum entries I read deal with HD stuff and wide screen but I don’t think really apply to me totally.
    I exported in quicktime conversion using the following
    H264
    data rate: 1500
    a custom scale to fit within 480×360. Preserved aspect ratio to fit within demensions. Deinterlaced the source video.
    Frame rate: Current
    Key Frames Automatic
    Quality: high
    Encoding: best quality multi pass
    Would it have been better to make an MP4?
    I had never done the dimension 480×360 before but it has been a while since uploaded on youtube and the shape of the window has changed. I think it looked pretty good.
    Anyhow, my main issue is that the picture is often choppy, especially when there is any camera movement. I’ve watched other videos which make me think that mine could be smoother.
    I tried doing it again experimenting with a Frame Rate of 30 and Key Frames every 30. It looked worse.
    What am I missing? Is the key to use Compressor? I don’t know what I’m doing with it.
  • David Roth weiss
    January 6, 2010 at 11:57 pm
    How long is the clip?
    Depending on your answer you might be able to use a much higher bitrate.
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
