Activity › Forums › Apple Final Cut Pro Legacy › Best eSATA HD for Macbook Pro
  • Best eSATA HD for Macbook Pro
    Posted by 671cam on February 19, 2007 at 11:13 pm
    I just bought a MBP 17 inch, 3gigs and 7200. I am Running FCP. I want to get a good Hard Drive set-up. Looking at Firmtek bus adapter and eSATA hard drive enclosures. What do you guys think of this set-up or what do you recommend? Also if I go with Firmtek what ATA drives do you recommend? I am mostly using HDV, DV and some BETA SP footage. Thanks!!!!
    George Loch replied 19 years, 7 months ago 2 Members · 1 Reply
  • George Loch
    February 20, 2007 at 5:10 am
    I was also looking for eSata options on my MBP and I took a cheap gamble on an Express34 card from Bytecc and it is working really well. It only cost $37 from Newegg.com and has been working well ever since. I am pretty sure it is Sata 150 and not Sata 300 but at this point it matters little as the MBPs seem to be hindered in over throughput from Express34 anyway. Unfortuantely, Newegg seems to have deactivated it on their website so I am not sure where else you can get it but you may want to check with their site:
    https://www.byteccusa.com/product/xP-card/bt-eces2.htm
    For enclosures, I went with the macsales.com options. I ended up with the Mercury Elite Pro which holds two drives and it is also working really well. All in all, the setup was really cheap and works beyond the expectation considering the price.
    -gl
