best effect to hide identity
Posted by Sean Brennan on August 19, 2009 at 4:08 pmWhat is it they use in those police programs to blur out number plates and faces?
Some look better than others, on the Jerry Springer show it’s done really well, what do they use do you think?
It’s taking me ages with a blur filter, following every frame, and adding hundreds of keyframes, still don’t look good!thanks
Peter Mcauley replied 17 years, 1 month ago 3 Members · 4 Replies -
Peter Mcauley
August 19, 2009 at 5:08 pmHi Sean,
You might want to try the BCC Witness Protect filter – it was designed with exactly this effect in mind. You can select between a mosaic, blur, brightness/contrast and color tint. Most people use the blur or the mosaic effect. There are complete instructions on how to use the filter on our web site in the tutorial section.
Cheers,
Peter.
Boris Yamnitsky
August 19, 2009 at 5:12 pmHere is the video tutorial that does exactly what you are asking for in Final Cut
https://borisfx.cachefly.net/borisfx/tv/tracker_081809.html
Enjoy,
Boris Yamnitsky
BorisFX -
Sean Brennan
August 19, 2009 at 6:19 pmany chance of a premiere pro version please? This does not help, I have following instructions and similar parameters but the tracker is going where it wants and not following the face at all!
Peter Mcauley
August 19, 2009 at 6:51 pmHi Sean,
BCC 6 should work in Premiere Pro 4.1.
I know that you had some trouble in getting this effect to deliver the result that you expected but you cannot expect a motion tracker to follow a pixel array without some degree of tweaking – even the most sophisticated trackers in the world need a little tweaking because no two clips are alike. Makes sense … right?
Go to the Preprocess group, enable the View Preprocess function by clicking on the checkbox (this is just so that you can see what you are doing) and tweak the parameters until the tracker successfully follows the pixel motion – this is how everyone does it. 🙂
I hope this helps.
Peter.
ps – if after a few attempt you still can’t get it to work please feel free to send me a small portion (less than 100 mb) of the clip via yousendit ftp service (which is free) and I’ll give it a shot myself.
