Activity Forums DVD Authoring Best DVDRipper
  • Best DVDRipper
    Posted by Ronald Lindkvist on September 10, 2008 at 9:43 am
    Hi guys,
    i have a ton of episodes to rip for my employer. I have played around with the first 20 different rippers, but none of the rippers out there, could actually do the job as i wanted.
    Some extort the sound level, some rips fine, but the rip can’t be opened afterwards in Premiere or Final Cut.
    I have tried xilisofts ripper, dvdfab, jesterware end many others. But which ripper do YOU find most professional.
    What I need is a compressionless rip to avi/mov/wmv with compressionless sound – aka a 1:1 rip that will open in a timeline afterwards.
    Any input will be highly appreciated, so thanks in advance!
    Regards
    Ron
    Lucas Fazzary replied 18 years ago 4 Members · 4 Replies
  • Eric Pautsch
    September 10, 2008 at 4:49 pm
    You need a tool that extracts assets form a disc, not rippers. Rippers remove CSS which is illegal.
    MPEG Stream Clip is what I use.
    https://www.squared5.com/
  • Brandon Donnelly
    September 10, 2008 at 10:48 pm
    Yiu can’t rip off a dvd and put it right into FCP, its not possible and if it is i wouldnt recommend that way as a ripping software wouldnt mean they know how to convert.
    A DVD must be ripped and will always give you a VIdeo TS folder which cannot be opened in FCP or premiere. You need to rip the dvd then convert all files in MPEG Streamclip to QT files (i do it this way)…..
    I use mac the ripper on mac then throw it into Streamclip then im ready to edit at a great quality level
  • Ronald Lindkvist
    September 11, 2008 at 8:26 am
    Thanks Eric and Brandon!
    I have learned something very valuable through your posts.
    I never understood, WHY I couldn’t open a directly ripped mov/avi/wmv file in any editors. I do now, and will try my newly obtained “technology” right away.
    Thanks thanks thanks 🙂
    Best regards
    Ron
  • Lucas Fazzary
    September 11, 2008 at 4:02 pm
    For Mac try Cinematize, for PC TMPGENC works great.
