Activity Forums Apple Final Cut Pro Legacy Best Drive solution?
  • Best Drive solution?
    Posted by Joseph Farris on May 20, 2005 at 2:13 pm
    Hello all, I’m wondering what the best/ least expensive drive solution is for doing uncompressed 10 bit HD work with a kona 2 system? I don’t need a ton of storage. Mostly short format work. Also, what kind of space is required per min of uncompressed 10 bit 720p footage vs footage captured with the DVCPROHD codec. thanks for your help.
    Joseph Farris
    Director of Photography
    Visions of Light, Inc.
    Office: 312-829-8244
    Pager: 800.808.8244
    Mobile: 630.306.8244
    Fax: 630.690.7678
    http://www.visionsoflightinc.com
    joe@visionsoflightinc.com
    Mitchji replied 21 years, 3 months ago 3 Members · 2 Replies
  • Jerry Hofmann
    May 20, 2005 at 4:09 pm
    AJA has a cool app downloadable from them to figure out storage space requirements for all formats… it’s in the Kona 2 support page… https://www.aja.com/support_kona.html look toward the bottom of the page.
    External SATA arrays will handle uncompressed 10 bit NTSC or PAL, however they aren’t going to be fast enough for useful storage of HD uncompressed, that would take at least a dual channel SCSI array. 4 gig Fibre would be better and folks like Huge Systems are getting ready to release 4 Gig Fibre solutions that will be the defacto standard I’d think very soon. They showed pre release hardware at NAB that could sustain 500 mb/sec… that’s enough for 3 streams of uncompressed HD… fastest SCSI is about half that.
    If you only need DVCPROHD captured material (via firewire for example) you can use much less expensive disk storage… in fact a fast FW 800 drive will suffice for it. it’s data rates are larger than DV, but at most a 1080i 60 DVCPRO native capture is only 13.7mb/sec… the 720 native codecs are even smaller. HD uncompressed can be well over 100mb/sec…
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Mitchji
    May 20, 2005 at 5:49 pm
    [Jerry Hofmann] “External SATA arrays will handle uncompressed 10 bit NTSC or PAL, however they aren’t going to be fast enough for useful storage of HD uncompressed, that would take at least a dual channel SCSI array.”
    Hi Jerry,
    HDCAM is not uncompressed but these results and the opinion sound promising:
    https://www.lafcpug.org/Tutorials/basic_storage_soltz.html
    Excerpt:
    “Below are benchmarks for this 4 drive raid using AJA’s Test Utility and the eSata8 card. The Tempo 4×4 card returned similar results. My own tests have given me 6 layers of realtime in DVCPRO HD 720p from footage captured from the Varicam as well as the ability to playback 8-bit 1080i HD. Granted this is from footage which was supplied to me and not captured on this system form HDCAM deck. It also was tested on a relatively empty drive. I would not recommend 8-bit uncompressed HD on this configuration. Based upon these benchmarks for a 4-drive raid, I do believe that an 8-drive raid would handle HDCAM.”
    Best Wishes,
    Mitch
