Activity Forums Apple Final Cut Pro Legacy best delivery format for playback from mac to tv monitor?
  • best delivery format for playback from mac to tv monitor?
    Posted by Alec Gitelman on October 21, 2009 at 5:46 pm
    Hi.
    I have created a video for a client to continuously play on their in-house monitor. I found out that their playback system is as follows: MacMini, 52” LCD 1080i, DVI-HDMI Cable.
    Most of the video is graphics created in After Effects, which I can easily scale. Some is footage shot on DV NTSC 24p, which I hope will uprez reasonably well. Unfortunately I am unable to visit the client and test their system with different files. Does anyone have experience with a similar setup? Should I create a 1080i file, 1080p, anything else? Do you suggest I uprez my video in AE? (I’m running FCP 5.1.4 here). And is there a data rate too high for a MacMini? Can it choke on too much H.264?
    Thanks.
    Alec.
    Ben Holmes replied 16 years, 11 months ago 3 Members · 4 Replies
  • John Fishback
    October 21, 2009 at 6:11 pm
    Is there a player of some kind, or do they simply play full-screen QTs (something else?) from the MacMini? More info is needed to make a recommendation.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 2 (FCP 6.0.5, Comp 3.0.5, DVDSP 4.2.1, Color 1.0.3)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • Alec Gitelman
    October 21, 2009 at 6:51 pm
    just playing full-screen qt.
  • John Fishback
    October 21, 2009 at 6:57 pm
    It’s tough not being able to test it out. My first inclination is to use H.264. Maybe you can test a mini at an Apple Store. Makeup a few short H.264 files at different data rates and see how they play. And I’d get the data rate up to 6Mbps. That is a similar data rate to one that would look good on a DVD.
    John
  • Ben Holmes
    October 21, 2009 at 11:51 pm
    You will need to ensure that the Mac mini is recent enough to handle 1080i h.264 files – they need a fair bit of processing – my home 1.66 Ghz one (which is a few years old) will only do 720p.
    Edit Out Ltd
    FCP Editor/Trainer/System Consultant
    EVS/VT Supervisor for live broadcast
    RED camera transfer/post
    Independent Director/Producer
    https://www.blackmagic-design.com/casestudies/detail.asp?case=therydercup
