Activity Forums Compression Techniques Best Compressor Setting For Text
  • Best Compressor Setting For Text
    Posted by Rocco Rocco on July 18, 2005 at 7:04 pm
    I’m having text issues, that I cannot seem to resolve. I use Livetype to create moving text, then drag the text into FCP5 and output to Quicktime. The outputted QT always produces poor quality text results (viewd on a standard Apple Flat screen). How Can I optimize this? What is the best way to insure I have great looking (sharp. rich) text. There are so many Compressor settings that I don’t know which one will produce the best results. THANKS!
    Charles Simonson replied 21 years, 2 months ago 2 Members · 1 Reply
  • Charles Simonson
    July 18, 2005 at 7:56 pm
    I’m guessing that the text you created in LiveType is then imported onto a FCP interlaced timeline (also, make sure your FCP render settings were set to Full Quality, as you may have accidentally rendered the text in draft quality). If so, there isn’t much to worry about, as this is normal, because interlaced content cannot be viewed accurately on a desktop monitor. That is why a pro-quality broadcast monitor is so important to a workflow. Even a standard TV does a better job displaying interlaced material than your desktop display. Anyway, to get rid of the quality issues you speak of, when compressing, if doing so for the web or other small format, make sure to de-interlace the content. However, you do not want to do this if you are not scaling down the video or are targeting TVs with MPEG-2 encoding at native size. If you are encoding for DVD, and the primary playback will be with a computer, then you should deinterlace the content, but quality will still suffer if your source is only D1.
