Activity › Forums › Compression Techniques › Best compression workflow FCP6 project for Bluray burning
  • Best compression workflow FCP6 project for Bluray burning
    Posted by Anne Davis on June 1, 2014 at 11:08 pm
    My Bluray burner came with Roxio Toast Platinum 11 and I’d like to try it for burning a Bluray disc
    os a short project (under 10 minutes).
    My version of Compressor is 3.0.5 so there is no “Share with Bluray” compressor preset option.
    I could use one of these Compressor presets:
    DVCProHD 720p24 (footage and editing codec used)
    HD DVD H.264 60 minutes
    HD uncompressed 8 0r 6 bit
    Should I use Compressor first, try exporting a Quiktime .MOV version of the timeline and dragging
    that file directly into Toast, or is there a better way I’m not considering?
    Rob Gutermuth replied 12 years, 3 months ago 2 Members · 1 Reply
  • Rob Gutermuth
    June 6, 2014 at 12:07 pm
    upgrade to FCS3 (FCP7) and use compressor for the encode, and Toast for authoring… that would be the ideal thing… but…
    there is a way to do it with your version of Compressor, by defining the MPEG 2 stream….
    One note; everyone says that creating MP4 files for blu-ray is a bad idea… and mpeg2 is much better… I never tried mp4’s even at H.264, so I can’t comment, but stick with having compressor make you mpeg2’s
    I think ken stone had something on this with earlier versions of FCS/Compressor… I would not use Toast to do the encode, since you own compressor.
    Rob Gutermuth
    Media Creations
