Activity Forums Apple Final Cut Pro Legacy Best compression setting
  • Best compression setting
    Posted by Dm Floyd on March 22, 2006 at 12:08 am
    I need help with audio compression settings for a program that is 1hr. 30 mins long. Cut program in fcp 4.5 mostly talking head, Exported as quicktime file, client needs windows media file to upload to their server. I use Cleaner for this. I want the file size to be relatively small so byte rate on video will be .242 at 240×320 frame size. What will make the audio smaller?? Any suggestions for byte rate here will be greatly appreciated. Or running it through another program….
    thanks in advance,
    dm
    Dm Floyd replied 20 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
