Activity Forums DVD Authoring Best Compression for Projection?
  • Best Compression for Projection?
    Posted by Daniel Wasserman on February 6, 2009 at 7:13 pm
    Hi –
    We just completed a doc and while waiting to hear back from the big festivals, we’ve had some invites to screen in smaller venues that unfortunately don’t have HD Cam. Our final digital output is DVCPro HD 720.
    First question is: which is better to screen off of, DVD or DV Cam? Second, does anyone know anything about this thing: https://www3.telus.net/bonsai/Step-by-Step.html
    I read in a forum that it might work for DVCPro HD 720 better than just using Compressor defaults, but it was a fairly old forum. Any help is greatly appreciated!
    Terry Mikkelsen replied 17 years, 7 months ago 4 Members · 5 Replies
  • Max Kovalsky
    February 6, 2009 at 8:44 pm
    Blu-ray is your best bet. Many festivals are already accepting submissions on the format and “On Location Memphis” will be actually screening on Blu-ray and 35mm exclusively during the fest.
    Max
    Blu-ray producer
    New York
    Area4.tv
  • Daniel Wasserman
    February 6, 2009 at 8:58 pm
    Hello –
    thanks, of course Blu-Ray is great. But these fests ONLY have DV Cam or DVD. Anybody else got any ideas?
  • Noah Kadner
    February 7, 2009 at 12:26 am
    I’d go DVCAM- I’ve seen DVDs stutter and halt at festivals- ugly. Also seen DV tapes do the same too because the projection DV player has seriously dirty heads. It’s a shame that so many ‘festivals’ go the cheap route to projection. Nothing beats a nice Beta SP, Digibeta, HDCAM or 35mm/16mm projection. At least they’re not going VHS…
    Noah
    Check out My My FCP Blog and my new RED Blog. Unlock the secrets of the DVX100, HVX200 and Apple Color.
    Now featuring the Sony EX1 Guidebook,
    DVD Studio Pro and How to Light Interviews.
    https://www.callboxlive.com
  • Terry Mikkelsen
    February 7, 2009 at 12:47 am
    The “bonsai” method sounds interesting, but I am skeptical. I will try a few scenes tonight and see what it does. Usually, for HDV footage, I edit as HDV, export a reference movie, and then transcode with Compressor. (Notice I said edit as HDV, not compositing.)
    Tech-T Productions
    http://www.technical-t.com
  • Terry Mikkelsen
    February 10, 2009 at 5:58 pm
    My gut was right. I cannot find settings or workflow that is worth the increased compression time. By going to another format/timeline you can get different looks, but nothing that really pops out. There are slight differences, which could be perceived by some as better, but to others maybe it is worse. And the differences are definitly slight! Even at 200%, you need to examine frame by frame for the differences, nothing that is worth noting at 100% in real time.
    With all of this in mind, along with the almost 2X time it takes to render/compress, I can’t justify it at all.
    p.s. I didn’t like any of the results when I applied gaussian blur, ranging in values from .1 to 1.
    Tech-T Productions
