Activity Forums Apple Final Cut Pro Legacy Best compression for BetaSP
  • Best compression for BetaSP
    Posted by Todd Mcmullen on August 25, 2008 at 4:05 pm
    HI all,
    I need to re-edit a program in FCP. My footage is BetaSP material. I have a considerable amount but wish to digitize at a compression that will enable me to not have to go back and do an on-line re-dig.
    Would pro-res HQ be the best option for Beta SP footage?
    Also, would SDI be a better input than component? or is there much of a difference?
    Todd McMullen
    Flip Flop Films
    Austin
    http://www.toddmcmullen.com
    Todd Mcmullen replied 18 years ago 5 Members · 6 Replies
  • David Roth weiss
    August 25, 2008 at 4:13 pm
    8-bit uncompressed or ProRes (non-HQ) will both do fine. You could splurge and go 10-bit or ProRes HQ, but you probably won’t notice much difference other than larger file sizes.
    SDI is better than componenet because there is no D to A conversion.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
  • David Bogie
    August 25, 2008 at 5:10 pm
    How are you connecting the Beta deck to your MAcintosh for capture?
    bogisan
  • Chris Poisson
    August 25, 2008 at 5:36 pm
    Going 10 bit is overkill, as Beta is 8 bit.
    Have a wonderful day.
  • Rafael Amador
    August 25, 2008 at 6:12 pm
    [Chris Poisson] “going 10 bit is overkill, as Beta is 8 bit.”
    Chris, Beta SP is Analog components.
    The higher the bit depth when digitizing an analog signal, the best.
    10b better than 8b.
    When you digitize audio you can increase the sample rate (44.1, 48, 96 Khz) and the bit depth (8, 16, 24 bits) to get a better signal.
    In digital video each standard have a sample rate that you can not change, but you can use a higher bit depth to get a better signal too.
    rafael
    http://www.nagavideo.com
  • David Roth weiss
    August 25, 2008 at 6:35 pm
    Funny, but I misread the original post from the get go. I saw the SDI and immediately thought Todd was asking about DigiBeta. So, I would agree with Rafael, 10-bit isn’t all bad, but ProRes works just fine as well.
    David Roth Weiss
    Director/Editor
    Los Angeles
  • Todd Mcmullen
    August 26, 2008 at 3:34 pm
    thanks everyone to your input.
    I will be coming out component to the kona 2 card. Or would it be better to come out component to an AJA component to SDI converter then to a kona 3 card. Seems it would be same.
    Todd McMullen
    Flip Flop Films
    Austin
