Activity Forums Adobe After Effects Best codec to use???
  • Best codec to use???
    Posted by Dotan Baytman on April 22, 2007 at 9:38 am
    I have a project i did in AE its 6 min and 640×480 its gonna shown on a laptop and the frame rate is 25 im not sure if i should use higher
    my question is im importing it to premiere so how can i get the best quality for the finished file?
    its gonna play from the computer so i don’t want a really heavy file
    what i did was export it from from AE using quick time animation codec and then imported it to premiere but now im not sure what codec to use cause the quick time is over 2 GB
    what is the best solution?
    Mark replied 19 years, 5 months ago 4 Members · 4 Replies
  • Michael Duff
    April 22, 2007 at 10:08 pm
    maybe some form of mpeg4 … quicktime h.264 would be good if you have QT7…. maybe sorenson3 if you want it to be more compatible with other machines……. try a few different options till you find what you want… you may even try DV or photoJPEG
  • Dotan Baytman
    April 23, 2007 at 9:19 am
    Thanx for the reply
    but isnt there some default good quality codec to use?
    like i said i used the quick time animation codec to premiere
    but then what to use?
    same codec? or different one cause the file is too big and not sure the other computer have quick time also don’t want to get lose resolution
    thanx
  • Kevin Camp
    April 23, 2007 at 7:59 pm
    dv or dv50 should play fine on most computers, the data rates are within firewire standards and the files won’t be too large. mpeg-2 wouldn’t be a bad choice either… if it’s good enough for the dvd industry it should be good enough for most other people. however, a third party utility may create better quality mpeg-2s than premiere, do you have adobe’s dvd authoring software?
    one other suggestion would be to work with progressive frames rather than interlaced. not only will it look better on a computer screen, but compression will usually have a less negative effect on image quality.
    Kevin Camp
    Designer – KCPQ, KMYQ & KRCW
  • Mark
    April 24, 2007 at 2:20 am
    I get pretty good results using AVI-microsoft DV as my setting. It will play fine on most computers. Also, as previously mentionned, render without fields.
    Mark
