Best Codec to use for 10-bit blackmagic with alpha channel!
I am keying 10-bit Blackmagic uncompressed footage in After Effects and trying to render a QT that looks decent when I put it back in my 10-bit Blackmagic sequence in FCP. Animation looks bad comparatively – what is the best work-around for limited compression with an alpha channel? Keying in FCP is nowhere near as easy and doesn’t have nearly the result as AE.
thanks!
