Activity › Forums › DaVinci Resolve › Best codec to render to when sending to Premiere Pro
  • Best codec to render to when sending to Premiere Pro
    Posted by Duke Sweden on September 22, 2017 at 10:47 pm
    If I do my color grading in Resolve, which lossless codec/wrapper should I deliver to so I can edit in Premiere pro? I checked, Tero, it’s not in the manual.
    Dell XPS 8920
    Intel i7 core 7700 build
    GeForce GTX 1050ti
    32 Gigs of RAM
    3 7200 RPM SATA Drives
    Windows 10 64-bit
    Premiere Pro CC 2017 v.11.0
    Duke Sweden replied 9 years ago 6 Members · 7 Replies
  • 7 Replies
  • Kevin Rag
    September 22, 2017 at 11:50 pm
    Hi Duke,
    A lot of my PC based industry friends use Cineform. Have you tried it? Or DNxHD is another good editing codec. I’m ProRes all the way since I’m on a mac.
    K
  • Chris Wright
    September 23, 2017 at 12:47 am
    are you using an XML to retain edit points? yea, cineform level 4/5 or dnxhr are really, really high quality, close to lossless.
  • Michael Gissing
    September 23, 2017 at 1:58 am
    I stick to DNx codecs. It has the added bonus that it is also the codec of choice if returning to Avid. DNx in mxf wrappers should be the default delivery codec as it is open and available, not closed and proprietary like ProRes.
  • Tero Ahlfors
    September 23, 2017 at 5:56 am
    If you absolutely need a lossless format I would go with DPX or EXR. The filesize will be huge but it’s lossless. Otherwise 10 bit DNxHD/DNxHR as mentioned in other comments. They aren’t straight up lossless but they are “visually lossless”.
  • Duke Sweden
    September 23, 2017 at 11:59 am
    That’s what I thought. DNxHD or HR. I was just wondering why Resolve defaulted to Quicktime in the Delivery section. It’s not like the list was in alphabetical order.
    Thanks, everybody.
    Dell XPS 8920
    GeForce GTX 1050ti
    32 Gigs of RAM
    Windows 10 64-bit
  • Glenn Sakatch
    September 23, 2017 at 3:11 pm
    I’ve been doing DNX444 to Premiere for 1 particular project, but because of either my lack of knowledge on how to change the color interprelation, or Premiere’s lack of ability to change how it reads a file, I select full levels in Resolve for my output. Blacks should then look proper in Premiere. 444 should be full, but I find Resolve, if left in Auto, outputs it at Video level, perhaps reading the DNX tag as more important than the 444 tag.
    Either way, set your levels to Full if going to Premiere.
    Glenn
  • Duke Sweden
    September 24, 2017 at 11:13 am
    Excellent. Thanks!
    Dell XPS 8920
    GeForce GTX 1050ti
    32 Gigs of RAM
    Windows 10 64-bit
