Activity › Forums › DaVinci Resolve › Best codec to export from Windows Resolve for Apple FCP on-line (for tomorrow)
Posted by Ben Edwards on January 3, 2014 at 7:27 pmHi, I have just finished grading a 30 min program for local telly. I am using Resolve 10 (Windows) and need to export a high quality graded file to be taken to the on-line (where audio mix and credits are to be added). It needs to be something FCP can read without installing any extra drivers. Prores 422 is no available on windows (which is what I would of used) so what should I use as a alternative?
It needs to be interlaced.
Sorry for cross posting but the director is picking up file tomorrow morning.
Ben
Ben Edwards – Freelance Picture Editor
https://www.funkytwig.comi5 3550 3.3Ghz, Windows 7 / Mac Lion, Nvida 550 Ti, 16GB Mem
Kelly Reese replied 12 years, 8 months ago 6 Members · 9 Replies -
Eric Johnson
January 3, 2014 at 8:13 pmUnless size/throughput is an issue, I would think uncompressed.
And even if size/thoughput are issues, a Pro Res can always be generated by the Online house…
eric b johnson
online editor | colorist | workflow
https://vimeo.com/39073239Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Ben Edwards
January 3, 2014 at 8:17 pmThanks, how do I do uncompressed (and how big is it likely to be on a 1/2 hour show)?
Eric Johnson
January 3, 2014 at 8:49 pmPretty certain it’s an option via the Quicktime render settings in Resolve…
According to Video Space, a 30 minute 1080 29.97 10b 422 (does not specify Interlace/Progressive) with 2 channel 16b audio is going to be approximately 260GB’s.
If that does’t work, I’d suggest researching whatever the available QT Codecs are on your Windows Resolve, and it would also be to your benefit to talk to Online to see if they have a preference based on what is available to your machine.
eric b johnson
Ben Edwards
January 3, 2014 at 8:52 pmThanks, I have Quicktime YUV and RGB 10b, are these both uncompressed, which should I use? Also will mac FCP read them OK?
Also the field processing check-box is rayed out, can uncompressed be interlaced, will it create 50fps?
Sascha Haber
January 4, 2014 at 9:18 amDNXHD 185 will probably do just fine for Broadcast..
A slice of color…
Resolve 10.0.0.073 , Smoke 2013 EXT
Colorist / VFX / Aerial footage nerd
https://vimeo.com/saschahaber -
Ben Edwards
January 4, 2014 at 9:34 amIt needs to be a codec that comes with mac/fcp 7 as standard. I am going for Quicktime YHV 422 but the field processing check-box is off, in needs ti be interlaced.
Andi Winter
January 4, 2014 at 12:55 pmif uncompressed can’t e interlaced, which i don’t know, then dnxhd185x would really be your
best option in my opinion as well. why it is a must that the online-house cant install any free decoding
codec? and there is a free package for decoding dnxhd on mac. just google it and send them the link
together with a one-second testclip (ie a greyscale ramp to check levels).this way you are on the safe side.
Marc Wielage
January 5, 2014 at 8:07 am[Ben Edwards] “Thanks, how do I do uncompressed (and how big is it likely to be on a 1/2 hour show)?”
Here’s a good iPhone app to compute expected storage requirements from various codecs and resolutions:Video Space Calculator
https://itunes.apple.com/us/app/video-space-calculator/id492916201?mt=8Note that Apple Compressor has some options for taking an uncompressed progressive file and then converting it to various interlaced formats, but getting those settings right takes some trial and error.
Kelly Reese
January 6, 2014 at 11:04 pmDNxHD works if they have the codec installed, but it greatly increases the chances of a gamma shift during the online and reduces the real-time perfomance in fcp7.
