Activity Forums Apple Final Cut Pro Legacy Best Codec (Need help asap!)
  • Best Codec (Need help asap!)
    Posted by Casey Baugess on July 18, 2007 at 7:30 pm
    I am capturing video through Kona LS from a beta sp tape to edit using the multi-cam in fcp 5.1. I have had success in the past using the uncompressed 10-bit codec, but the files are so big. I can’t seem to get Photo-Jpeg to work (even when rendered to 10-bit on timeline), are there any other codecs that will work with the multi-cam edit while keeping the best broadcast quality? Thanks!
    Mac OS X.4.9
    FCP 5.1
    Casey
    Russell Lasson replied 19 years, 2 months ago 2 Members · 1 Reply
  • Russell Lasson
    July 18, 2007 at 10:35 pm
    I like to use DV50 when uncompressed is over kill. It’s a great SD codec.
    Or if you’re on a FCP6 system, you might try a SD ProRes codec.
    -Russ
