Activity Forums Adobe After Effects best codec for video??
  • best codec for video??
    Posted by Katshiva on August 9, 2005 at 5:24 pm
    What’s the best codec for video?
    I have to export my footage which is in H.264 to another codec so my AE 5.0 will be able to read it. I’m running old ae 5.0 w/old quicktime 5.0. Would h.263 be the next best thing? Or animation codec or Mjpeg?
    Katshiva replied 21 years, 1 month ago 2 Members · 2 Replies
  • Steve Roberts
    August 9, 2005 at 7:06 pm
    In your situation, you’re transferring video from one app to another for further rendering. You want an intermediate, low-compression (actually lossless) high-quality codec. Use Quicktime’s Animation codec at 100%.
    Remember, this is not a delivery codec, so it will not play back smoothly on your computer because its compression is so low, and as a result, its data rate is so high. At the end of the project, choose a delivery codec so you can play back the file for your chosen final medium. That could be Sorenson or Windows Media 9 for the web, DV for tape, or a broadcast codec that your editor uses for eventual broadcast (Avid, media 100, Blackmagic, etc.).
    Hope that helps,
    Steve
    P.S. No need to double-post. 🙂
  • Katshiva
    August 9, 2005 at 8:16 pm
    thanks!
    That’s what I’ve been using – the animation codec, but I wasn’t sure what setting I should use for the motion/key frames in QT7? should it be automatic, every or all? I read that it should be none but that was for the old QT5, and this option doesn’t exsist for QT7.
