Activity Forums Adobe Premiere Pro Best Codec for Use in Premiere Pro CC 2015 for Mac
  • Best Codec for Use in Premiere Pro CC 2015 for Mac
    Posted by Dan Destefano on October 13, 2015 at 5:28 am
    Hi Guys,
    So I tried to do the whole, “use whatever codec you like” thing, and it’s not working out. I converted everything to ProRes 422 and things work much better. BUT, I was wondering what Premiere likes best, codec-wise. I know FCP liked the ProRes codecs best, but what’s best for Premiere?
    Stephen Abbott replied 10 years, 10 months ago 3 Members · 2 Replies
  • Shane Ross
    October 13, 2015 at 5:56 am
    ProRes is great. So is DNxHD.
    Shane
    Little Frog Post
  • Stephen Abbott
    October 13, 2015 at 7:12 am
    Hi!
    Not sure whether you’re referring to the footage codec or the sequence codec.
    Footage codec:
    I’ve had mixed results using camera-native codecs. Transcoding to ProRes or DNxHD before offline is definitely snappier, but for small-ish jobs I often just bring in whatever MPEG2 or 4 the camera recorded in. This depends on your machine, of course—the CPU, GPU and disk(s) speed.
    Sequence codec:
    I always use either a flavour of ProRes or DNxHD. I render as I go, and then when it comes to exporting, I select ‘use sequence previews’ and the export is pretty much as fast as the disks can handle it. This is analogous to the old FCP7 ‘export as FCP Quicktime movie’ option.
    Stephen Abbott
