Activity Forums VEGAS Pro best codec for rendering AVI files in Sony Vegas
  • best codec for rendering AVI files in Sony Vegas
    Posted by Eruj Haque on August 19, 2009 at 7:12 pm
    i have for footage in 16:9 30p
    i am applying some effects and color correction using FXBlue
    after i rendering with default (‘Best’) AVI DV widescreen in sony vegas .. my video quality dosent look that sharp, it look more like i am playing a video cassette… what codec should i use to reneder AVI in Sony Vegas for the best possible quality ?
    also i need a 20 minutes video not to go over 4-5 GB
    Ken Kasriel replied 16 years, 11 months ago 5 Members · 4 Replies
  • Theo Van laar
    August 19, 2009 at 10:24 pm
    What will be your end product? DVD? Then your codec should be MainConcept MPEG2 for video and AC3 for audio.
    Theo
  • David Ludwig
    August 21, 2009 at 5:16 pm
    i’ve had good results with the cineform codec.
  • Ben Longden
    September 27, 2009 at 7:13 am
    In the render section, use the .AVI template, and make sure it fits with your current project settings (like NTSC/PAL, 29.97 or 25fps, 16:9 or 4×3 and screen pixel sizes).
    For me, I use the standard PAL DV widescreen template (Im in PAL land and shoot widescreen 720×576)
    For the video quality, check the “best” box.
    The acid test is when rendering an “untweaked” avi clip, is to see the words “recompression not required” in the preview window.
    If you get that, all should be well with the world. Reapply your tweaks, and render.
    HTH
    Ben
  • Ken Kasriel
    October 25, 2009 at 11:36 pm
    I have just recently come across the Lagarith Lossless Codec
    https://lags.leetcode.net/codec.html
    and have achieved some very nice renderings from Vegas with it. In fact it is the best I’ve found after spending several hours doing systematic comparisons of various codecs (done because I have some footage with some very fine details which need to be preserved).
    Lagarith not only looked better to me than some other really good codecs (like Huffyuv and DivX) but creates reasonably small files — in my trials, they were 10-20% the size of the underlying, uncompressed files.
    Hope this helps… good luck
