Activity Forums Apple Final Cut Pro Legacy Best capture setting for HDCAM
  • Best capture setting for HDCAM
    Posted by Matt Shires on August 3, 2008 at 8:08 pm
    I’m new to HD and was asked to digitize a couple of short films mastered onto HDCAM. I was wondering what are the best capture settings for the Highest resolution possible? Would uncompressed 10-bit pal be suitable for the task?
    I’ll be capturing through a BlackMagic Multibridge Extreme from a Sony JH3 Deck.
    I know the multibridge is capable of Dual-HD SDI but have no idea whether this improves picture quality, speed or is at all necessary in this instance? also which would be better; 10 or 8 bit?
    Any help would be greatly appreciated,
    Much Thanks, Matt
    Matt Shires replied 18 years, 1 month ago 4 Members · 6 Replies
  • David Roth weiss
    August 4, 2008 at 12:40 am
    The correct answer all depends on your hard drive sub-system. You will not be able to capture 8 or 10-bit uncompressd without dropping frames unless you are running a rather “beefy” raid. If not, then you would want to consider capturing to a compressed format such as DVCProHD or ProRes.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
  • Walter Biscardi
    August 4, 2008 at 1:18 am
    [matt shires] “I’m new to HD and was asked to digitize a couple of short films mastered onto HDCAM. I was wondering what are the best capture settings for the Highest resolution possible? Would uncompressed 10-bit pal be suitable for the task? “
    If you have a high speed hard drive array capable of at least 250MB/s sustained speed, you can capture to 10bit Uncompressed High Definition. Better to be over 300MB/s to ensure you don’t drop frames.
    The speed of your array is going to determine what you can do.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
    Read my Blog!
    View Walter Biscardi's profile on LinkedIn
  • Matt Shires
    August 4, 2008 at 11:46 am
    What’s the best method of finding out your disk speed,
    we’re currently working on a Fibre Optic SCSI Raid unit with 1TB, would this be quick enough?
    Many Thanks, Matt
  • Gary Adcock
    August 4, 2008 at 3:31 pm
    [matt shires] “we’re currently working on a Fibre Optic SCSI Raid unit with 1TB, would this be quick enough? “
    is it a SCSI raid or a Fibre Raid?
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    Inside look at the IoHD
  • David Roth weiss
    August 4, 2008 at 4:03 pm
    [matt shires] “What’s the best method of finding out your disk speed,”
    Run the Disk Speed Utility from BM, it is usually installed on your computer along with the BM drivers.
    David Roth Weiss
    Director/Editor
    Los Angeles
  • Matt Shires
    August 7, 2008 at 9:49 pm
    Thanks for the reply’s, they really helped.
    Checked my disk speed and it’s slighty over 260mb/s so probably end up using prores422.
    Aside from the best capture, what’s the benefit in using dual-hdSDI from the decklink?
