Activity Forums DVD Authoring Best Capture Codecs
  • Best Capture Codecs
    Posted by Tarquin Douglas on April 5, 2009 at 7:50 am
    I just wanted to know what anyone else is using to capture in material for encoding to MPEG2.
    I am using a BlackMagic SDI Card on MAC OSX. Source is PAL 720×576 DigiBeta. MPEG 2 is encoded with Cinemacraft.
    I have always used NONE to capture in as file sizes are not an issue but one one recent job the final encode looked noticably Darker in a couple of scenes. The source is a feature all shot at night.
    I ended up using “Uncompressed 8bit” which gave slightly lighter results but with slightly less satuartaion.
    Any workflows/codecs anyone else uses would be good to know.
    Cheers,
    T
    Tarquin Douglas replied 17 years, 5 months ago 2 Members · 2 Replies
  • Michael Sacci
    April 5, 2009 at 6:54 pm
    Use 10-Bit Uncompressed, only slightly larger file size than 8-bit but why not keep all the color info you can.
    I have read about issues using “NONE” the Uncompressed setting is just safer to use and there is no compression happening.
    There will always be a quality lose when going to m2v files, they are highly compressed and you are going down from 4:2:2 color space to 4:2:0, the quest is to keep it as close to the original footage as possible.
  • Tarquin Douglas
    April 6, 2009 at 7:25 am
    Thanks Michael,
    I’ll give the 10 bit Uncompressed a go.
    Cheers,
    T
