Activity Forums Compression Techniques Best box/software for realtime MPEG2 compression with CC?
  • Best box/software for realtime MPEG2 compression with CC?
    Posted by Cathy Mayville on April 12, 2012 at 4:15 pm
    Hi! I use Avid, Final Cut and soon will use Premiere to edit :30 promos and long form docs for broadcast.
    I now need to deliver digital (MPEG2 ts’s) for broadcast. I also have to deliver MPEG2 ts’s for VOD and I
    HAVE to keep the CC intact (which comes to me embedded in HD and SD tapes, not as a separate file)
    I am going to NAB to look for a device (box? Software) that will allow me to play my sequence out in real time, then convert it to MPEG2 ts WITH CC, and will then distribute the files to various broadcasters for air and VOD.
    I am looking for some advice on what companies to talk to about NAB, that could help me accomplish this.
    My first guess is Telestream, but not sure they can help me. Anyone else? Thank you!
    Mac 2×3 Quad core intel Xeons
    16 gb RAM
    AJA Kona LHi
    Thanks! Cat Mayville
    Mac 2 x 2.93 Ghz Quad Core Intel
    OS 10.6.4
    16 GB RAM
    Kona LHi V 9.0.6
    Final Cut Pro 7
    Episode 5.3.2
    Gary Hazen replied 14 years, 5 months ago 3 Members · 4 Replies
  • Craig Seeman
    April 12, 2012 at 4:24 pm
    [Cathy Mayville] “My first guess is Telestream, but not sure they can help me.”
    Sure they can. Episode Engine cluster.
  • Cathy Mayville
    April 12, 2012 at 5:45 pm
    Thanks Craig! I will check them out for sure. Anyone else I should go see?
    OS 10.6.4
    16 GB RAM
    Kona LHi V 9.0.6
    Final Cut Pro 7
    Episode 5.3.2
  • Craig Seeman
    April 12, 2012 at 9:09 pm
    Harmonic comes to mind as well in that field.
  • Gary Hazen
    April 13, 2012 at 7:06 pm
    [Cathy Mayville] “Anyone else I should go see?”
    Digital Rapids and Viewcast.
