Activity Forums VEGAS Pro Best black levels / contrast tools
  • Best black levels / contrast tools
    Posted by Frank Manno on January 30, 2011 at 12:02 pm
    Hi all..
    What are the best tools in Vegas 9 and 10 to make contrast adjustements? Also, black level adjustements. Or posssibly a plugin maybe??
    The ‘brightness contrast’ plugin that is standard isn’t too good.
    I used to use magic bullet which gave me not bad results but I’m not using it anymore due to it not supporting 64 bit and am now findind myself looking for another way to adjust contrast/brightness and blacks.
    -Frank
    Brian Shircliffe replied 15 years, 7 months ago 5 Members · 4 Replies
  • John Rofrano
    January 30, 2011 at 2:11 pm
    [Frank Manno] “What are the best tools in Vegas 9 and 10 to make contrast adjustements? Also, black level adjustements. Or posssibly a plugin maybe??”
    Color Curves is probably the best and easiest too use. It will allow you to bring your luminance into broadcast safe levels and adjust the gamma curve at the same time. You can also use the Levels filter in conjunction with this.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Scott Francis
    January 30, 2011 at 3:52 pm
    Color curves is my go to for level and brightness. I also use Secondary color corrector to make fine tune adjustments as well.
    Scott Francis
    Mind’s Eye Audio/Video Productions
  • Mike Kujbida
    January 30, 2011 at 3:57 pm
    Another vote for color curves being the best tool for the job along with a recommendation for the Absolute Training for Vegas+DVD, Vol. 4: Color Correction, Enhancement and Image Restoration DVD Absolute Training for Vegas+DVD, Vol. 4: Color Correction, Enhancement and Image Restoration DVD fro VASST to easily learn the intricacies of this and other CC tools.
  • Brian Shircliffe
    February 2, 2011 at 6:59 pm
    I say the color correction with the gamma, gain, offset, and saturation are good while you are looking at your scopes. I use an old 24″ CRT to really see the full color gamut for blacks honestly I try to keep the blacks really black… I don’t do work for TV so I can get away with full range levels but I think it’s best to adjust each clip for it’s unique qualities. eyes are the best tool.
