Best Audio Preset for Narration or Voiceover?
Posted by Blayde Stone on May 30, 2010 at 10:01 pmIs there a Sony Audio plug-in or existing software that would produce or emphasize that FM smooth Jazz Radio announcer Voice sound ??
Assuming of course that the Original Audio was “close miked” and clear. Your input is always appreciated, Thanks…
Blayde @ CornerstoneBlayde Stone replied 16 years, 3 months ago 4 Members · 8 Replies -
Scott Francis
May 30, 2010 at 11:48 pmDo you have Sony Sound Forge?
Scott Francis
Mind’s Eye Audio/Video Productions -
Blayde Stone
May 31, 2010 at 12:25 pmMorning Scott, Thanks for your response, I just downloaded Trial of
Sound Forge Pro, where do we go from here ? -
Scott Francis
May 31, 2010 at 12:58 pmTry inserting the “Wave Hammer” fx into your audio track, select the “voice” preset and tweak till you feel you are getting the desired results. Also the “track compressor” can also be reasonable to try as well, but wavehammer has a few more presets….good luck!
Scott Francis
John Rofrano
May 31, 2010 at 1:27 pmYou don’t need Sound Forge to get Wave Hammer anymore. Vegas Pro comes with Wave Hammer Surround so you can do this all in Vegas. That FM radio announcer voice can be achieved with a little bit of EQ and a lot of compression. I agree with Scott, the “Voice” preset in Wave Hammer Surround is a good place to start.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Blayde Stone
May 31, 2010 at 1:41 pmThanks to the both of you , I just did notice that “Wave Hammer” is in My Vegas Pro, and hopefully later today we will put it to the test..
BTW approx.how much “compression” would one apply,or is this just a trial and error thing ????
P.S. REMEMBER OUR VETS….
Bob Peterson
May 31, 2010 at 3:11 pmYou should also consider any other audio tracks. When voice over is used, it is a good idea to apply a notch filter to keep those tracks from stomping on the voice or narrative. I don’t recall if there is a built-in preset for this.
John Rofrano
May 31, 2010 at 4:00 pmBTW approx.how much “compression” would one apply,or is this just a trial and error thing ????
As was suggested, start with the “Voice” preset and “season to taste” from there. When you hear too much pumping or the noise floor is too great, it’s probably time to back off a little.
~jr
